Old 05-03-2017, 03:20 PM   #43
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Anything over 10PPM of CO can cause health effects.
Anything over 150PPM can kill you.
Modern cars with properly working cats still put out around 1,000PPM
Although this is far better than the 80,000 to 100,000PPM that the old cars put out it is still lethal.
You will die from CO poisoning in an enclosed space well before you will suffocate from burning up the available oxygen.
https://www.abe.iastate.edu/extensio...rages-aen-207/
You are misreading the data. Modern cars put out a typical 100PPM, but can reach up to 1000PPM when cold started (e.g. catalytic converter not warmed up).
Now a charcoal grill - that will get you 3500PPM easy!
nextcar is offline   Reply With Quote
Old 05-03-2017, 03:31 PM   #44
Not misreading, mistyping. I should have said "up to 1,000"
Still plenty to kill you. And that is with a perfectly running car with zero leaks or other issues.
But, like you said, a grill, water heater, furnace, etc can put out even more and kill you faster.
The point I am making is that there is still plenty of CO coming out of a car even with cats in place. It still kills many people a year and will continue to as long as they are dumb enough to run their car inside.
PandaSPUR (05-03-2017)
Old 05-04-2017, 04:23 AM   #45
Dake
Dake's Avatar
I'll echo the common sentiment, AC works great unless I'm at a dead-stop, facing the sun in the Houston summer.
I'd like to focus on the other part of the question though - are you running with the AC off in an attempt to save gas iow with the windows down, or just trying to cool the cabin via vent air?
Because the windows down is less efficient than running the AC and keeping the car buttoned up.
Dake is offline   Reply With Quote
The Following 2 Users Say Thank You to Dake For This Useful Post:
Dadhawk (05-04-2017), Tcoat (05-04-2017)
Old 05-04-2017, 11:22 AM   #46
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
Thanks, I'm aware of that. I'm a motorcycle rider. I like the natural air, as long as it's not 90º+.
bkharmony is offline   Reply With Quote
Old 05-04-2017, 07:56 PM   #47
Dake
Dake's Avatar
Right on!
Air Conditioning Problems Shark Issues | Warranty | Recalls / TSB 29 10-02-2024 05:03 PM
Delete of Air Conditioning 000 Racing Engine, Exhaust, Transmission 27 07-03-2016 11:26 PM
Air conditioning gets warm when rpms go up hahaman86 Engine, Exhaust, Transmission 25 09-22-2014 01:02 AM
Air conditioning Moldy smelling njccmd2002 Issues | Warranty | Recalls / TSB 15 05-12-2013 10:34 AM
WTB: Air Conditioning Condenser - Drats! cobrabyte Miscellaneous 3 03-20-2013 09:29 PM
