#15 |
Drives: 2014 Whiteout FRS
| The Following User Says Thank You to Wyattkb For This Useful Post: | pevsfreedom (04-23-2017) |
#16 |
Drives: 2014 BRZ
#17 |
Drives: 2014 BRZ
Alright well I added a washer that was about 2x the thickness and still the same issue; no difference.
What's interesting is if I'm going 6000 rpm or whatever (super rattle) and pull up on the "lever" or whatever it's called (to go into reverse) it goes away. This is at any RPM. If I pull the knob up it stops rattling... any ideas? Still waiting for the dust cover to come in, but the bigger washer didn't help. HELP!!!! |
#18 | |
Sent from my Pixel using Tapatalk |
#19 |
Drives: 2014 BRZ
Brand new. I've opened it up and "reinstalled it" 6 times now or so. Only thing I can think of is the washer isn't big enough (new one is about 2x the size) or it's the dust cover)... or it's a faulty unit, or something else that I can't think of.
#20 | |
Take your shift knob off and drive, if it still rattles take the reverse lockout off and take it for a drive. See if it's one of those 2 things. Sent from my Pixel using Tapatalk |
#21 | |
Drives: 2014 BRZ
#22 | |
#23 |
Drives: 2014 BRZ
Oh I see. Not sure how to get that off.
I've tried every other damn thing. Even drove with it all off basically and yeah still rattlin'. Kinda wanna throw the stock shifter on to see if it still happens to identify if it is in fact the new Kartboy or the dust cover that's missing. At this point I think there's something wrong with the unit as I've put 10+ hours into troubleshooting this thing. Last edited by pevsfreedom; 04-24-2017 at 03:08 AM. |
#24 |
Drives: 2015 ISM BRZ Premium
Did you put the little rubber washers on that Kartboy supplies with these now?
I recently installed one and have a similar rattle in all even-numbered gears and assumed it was rattling against the reverse lockout plate. I had a rattle from the Kartboy SS on my bugeye and the "fix" was to dremel out a larger hole. It hasn't been loud enough to really bother me (especially when competing against intake, exhaust, and music). You're not going to be able to remove the plastic reverse lockout piece on the Kartboy--this is part of the shifter. |
#25 | |
Drives: 2014 BRZ
What is weird to me is when I pull up the lever the noise goes away. I'm positive I've installed everything correctly, besides ripping off the dust cover =/. I also bent the little "dust cover" that goes on the bottom of the shifter (from the stock one, probably from messing around with the whole assembly so much), which I can't for the life of me find a part # for but doubt it'd cause a metal rattle sound. |
#26 |
Drives: 2017 Series.Yellow, 2005 LGT wagon
Check this thread: http://www.ft86club.com/forums/showthread.php?t=98475
I'm on the stock shifter and get inklings of rattle at 3.5k, it really starts to buzz at 5k+. I plan to replace the nylon bushings and rubber o-ring, possibly doubling the o-ring, and then greasing everything thoroughly. |
#27 |
Drives: 2014 BRZ
I put in a steel washer that was twice as thick; might try adding an o-ring next. I added a 1lb shift knob to it and it actually helped quite a bit.
#28 | |
You actually can remove the plastic reverse lockout piece. There is a small pin near the top that you can tap out and then it just slides off. I did this and added some extra grease in there. |
| FS: Kartboy Shortshifter | byun | Transmission and Driveline | 12 | 01-26-2016 12:28 AM |
| [FS]RCE Yellows, Kartboy UDP, Kartboy shifter stay bushing | Calum | Brakes, Suspension, Chassis | 11 | 11-03-2015 07:19 PM |
| shortshifter with stock reverse lockout? | enjoi23 | Engine, Exhaust, Transmission | 1 | 04-03-2014 05:33 PM |
| >> Kartboy Sale - 10% off all Kartboy Items at RallySportDirect.com!! << | RallySport Direct | Announcements, Contests, Giveaways | 1 | 07-17-2013 09:28 PM |
| BPS Shortshifter for FRS review | gonzo | Engine, Exhaust, Transmission | 16 | 12-14-2012 09:42 PM |
