#15 |
Drives: 13 SWP BRZ Prem
My guess is you are sitting at a light, the car is out of gear and your foot off the clutch.
The light Turns green, you push the clutch in, and shift into first. You hear a clunk noise and feel the shifter move. This is normal When your transmission is out of gear and your clutch is engaged, the input shaft of the tranny is spinning with your engine and flywheel. As @Ultramaroon stated, the input shaft has enough rotating mass that it will continue to rotate for a short duration after your push the clutch in. That rotation will torque the synchro and gear when you select a gear and create a noise and feeling you described. Now, if you push the clutch in and wait a couple of seconds (maybe 3) the input shaft will have stopped spinning and you won't get that anymore. If you have driven hondas or other FWD vehicles in the past that have cable linkages or other longer/more complicated linkages, the play in the system may have isolated you from that noise and feeling before.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice 191WHP/151 ft-lb on 92 |
| The Following 3 Users Say Thank You to Imrac For This Useful Post: |
#16 |
I'm still trying to figure out how he got a 17' transmission in there.
That's longer than the car. |
| The Following User Says Thank You to Tokay444 For This Useful Post: | Ultramaroon (04-14-2017) |
#17 |
| MANUAL TRANSMISSION | Anthony7515 | NY / NJ / CT / PA | 10 | 05-13-2016 03:36 PM |
| MANUAL TRANSMISSION | Anthony7515 | Southern California | 1 | 05-12-2016 02:42 PM |
| Is the frs/brz your first manual transmission car? | swarb | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 03-04-2015 09:22 PM |
| Manual transmission 2nd into 1st | MrMista | Engine, Exhaust, Transmission | 9 | 10-13-2013 11:48 AM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 08:54 PM |
