#393 | |
Drives: FRS Silver LS1 swapped.
#394 |
Drives: 2013 Ultramarine FR-S
Hey @cf6mech. Any chance you know What the choke diameter is on the headers from Vorshlag?
The Four Pipes merge into one and it's smaller than 3". It then expands into 3". ![]() I am seeing this quite a bit as I am looking at collectors. Starting to think just cutting the headers at the end of the merge and transitioning to 3" may be the way to go instead of just trying to make it 3" straight off the bat. I.E. 1 7/8 to 2.5" Merge to 3" Outlet From Vibrant ![]()
#395 |
Not really sure Dustin, would have to get underneath the car to check it out.
#396 |
Fuel Components came in. Still waiting on the FPR by-Pass which is due for delivery Saturday, and fuel line which is suppose to ship first of next month (summit doesn't seem to stock Vibrant Hose). With the 25' I have should cover a feed and return set-up. Few other things trickling in.
![]() Lots of Vibrant fittings. ![]() ![]()
#398 |
Drives: 2017 WR BLUE BRZ
You could open up a speed shop with all the stuff you have in your inventory haha!!
#399 | |
#400 |
Drives: Silver 2013 Subaru BRZ
#401 |
#402 |
Well. One of the final pieces of the puzzle.
![]() So excited Also. Hood pins and trans tunnel wrap came in.
#403 |
Oh S***. Good Friday has been amazing....
#404 |
Its happening!
#405 |
Dooood! And I was about to offer you my set of mounts so you could get the project moving!
Now we get to see this project move into top gear! |
#406 | |
Any idea on when you start yours? Engine is still a couple weeks out if it was anything like mine. Edit: Realized I never posted the pictures for the Clutch master cylinder (At least I couldn't find them) Difference in length and thread pitch ![]()
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| Ls or 2jz swap? | sgoldberg01 | BRZ First-Gen (2012+) — General Topics | 13 | 03-22-2016 03:07 PM |
| Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-21-2015 11:38 PM |
| AT-->MT swap | AlwaysSideways | Want-To-Buy Requests | 3 | 12-15-2014 11:14 AM |
| Should I swap? | michaelahess | BRZ First-Gen (2012+) — General Topics | 8 | 06-12-2012 07:32 PM |
