Drives: 2014 Frs
No brake light, dash showing abs and traction
As the tittle saids, I'm getting no brake light when I step on the brake, I can't take it out of P because it's not sensing the brake. Fuse 4,6,14,15 looks good.
Anyone know what's the problem? |
#3 |
You might check fuses 13,16 and 26.
humfrz |
#4 |
Drives: 2014 Frs
#5 |
Drives: FT86
Check the brake pedal switch. If the brake pedal switch is stuffed, the you will get no brake lights, wont come out of park or start as ecu wont detect brakecpedal pressed and may upset vsc traction system as it wont know brake pressed Could be brake switch at pedal or the wiring\plug |
#6 | |
Drives: 2014 Frs
#7 |
Señor Member
A friend of mine had this same exact issue and it was the brake switch that needed to be replaced.
#8 |
Drives: 2014 Frs
just checked, no continuity coming from switch. No difference in meter when pressed or not
Also it's loose like crazy, is there a spring feed back or something? Like it's suppose to feel like a mechanical keyboard ? |
#9 |
Drives: 2014 Frs
Update: turns out is the brake light switch under the peddle.. we cracked it open and it was burnt.. we pushed out the contacts now its good.. temporary fix so I don't get a ticket. called wholesale parts through shop and it will be here tomorrow. There's only one in california from Toyota other than that it will have to be shipped from Portland. Subaru takes 3-4 days.
| The Following User Says Thank You to ducky369 For This Useful Post: | steve99 (04-11-2017) |
| DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video | continuecrushing | DIY (Do-It-Yourself) Guides | 44 | 11-23-2020 07:17 PM |
| Brake light on dash comes on when stopping | sjcurtis | Issues | Warranty | Recalls / TSB | 17 | 03-15-2017 10:29 PM |
| Engine Check light, Traction Control light, cruise control light all on suddenly | wqc3241 | Software Tuning | 2 | 01-10-2016 08:37 AM |
| ABS, Traction control and brake light??? | JMoore412 | Issues | Warranty | Recalls / TSB | 18 | 08-20-2014 06:09 PM |
| Traction control, abs and brake light all on? | JMoore412 | Issues | Warranty | Recalls / TSB | 0 | 08-12-2014 08:27 PM |
