#15 |
Drives: between cars...
Perhaps, but I personally wouldn't want to jump through all the extra hoops to prove that your modification was not the cause of the issue. Any chance you think the chirp could be from the couplers/flanges in the OFH from the engine moving under load?
#16 | |
It's in the clutch master cylinder. Some blame it on the delay valve. In my case the return spring occasionally rattles at about 4200-ish RPM (IIRC, been a while) when it's really hot and only with my foot off of the pedal. I get tip-in knock when I stab at the throttle from fuel cut. (engine braking) I've learned to ease into it to avoid it. Totally stock.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | nastynate88 (04-05-2017) |
#17 |
Car Dilettante
Drives: Nikki
My car had the same issue! Took it to Toyota and the warranty covered the fix and they told me with was the "high pressure fuel pump". No more chirp for me, I hope that helps a bit
#18 | |
Drives: 13' Satin White Pearl BRZ
The #1 rule of dealers, if you modded it, it's the mods that caused the issues and you as a client need to prove it's not.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
| Remote door lock "chirp" | ArtS | Electronics | Audio | NAV | Infotainment | 12 | 09-11-2015 01:35 PM |
| 2015 Series.Blue Engine "Chirp"and 2nd Gear Grind | s30series | Issues | Warranty | Recalls / TSB | 33 | 09-07-2014 02:26 AM |
| Switching back to 17" Wheels from 18" for acceleration feel? | bobsacamenoh | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 08-30-2014 08:35 PM |
| "Buzzing" From behind the steering wheel under hard acceleration | husker741 | Issues | Warranty | Recalls / TSB | 13 | 06-30-2013 02:18 PM |
| Steering wheel/dash "rattle?" upon heavy acceleration? | brett_g | Issues | Warranty | Recalls / TSB | 2 | 08-04-2012 05:52 AM |
