Old 04-03-2017, 03:19 PM   #15
imnotsureaboutbrz
Drives: between cars...
Originally Posted by nastynate88 View Post
What funny about it? The car is under 3 years old and less than 36,000 miles. Modifying your car doesn't nullify your warranty.
Perhaps, but I personally wouldn't want to jump through all the extra hoops to prove that your modification was not the cause of the issue. Any chance you think the chirp could be from the couplers/flanges in the OFH from the engine moving under load?
imnotsureaboutbrz is offline   Reply With Quote
Old 04-03-2017, 05:22 PM   #16
http://www.ft86club.com/forums/showthread.php?p=2565234
Seems this person had a similar issue, but no follow up.
Not me. I was just trying to be helpful.
It's in the clutch master cylinder. Some blame it on the delay valve. In my case the return spring occasionally rattles at about 4200-ish RPM (IIRC, been a while) when it's really hot and only with my foot off of the pedal.
I get tip-in knock when I stab at the throttle from fuel cut. (engine braking) I've learned to ease into it to avoid it. Totally stock.
nastynate88 (04-05-2017)
Old 04-05-2017, 05:51 PM   #17
c0nnexi0n
Car Dilettante
c0nnexi0n's Avatar
Drives: Nikki
My car had the same issue! Took it to Toyota and the warranty covered the fix and they told me with was the "high pressure fuel pump". No more chirp for me, I hope that helps a bit
c0nnexi0n is offline   Reply With Quote
Old 04-05-2017, 07:59 PM   #18
Chronology
Drives: 13' Satin White Pearl BRZ
Good luck telling that to any stealership. I don't know about your tune, but with ECUTek and flashing stock, the dealer can tell a ROM was loaded outside of Toyota/Sub.
The #1 rule of dealers, if you modded it, it's the mods that caused the issues and you as a client need to prove it's not.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Remote door lock "chirp" ArtS Electronics | Audio | NAV | Infotainment 12 09-11-2015 01:35 PM
2015 Series.Blue Engine "Chirp"and 2nd Gear Grind s30series Issues | Warranty | Recalls / TSB 33 09-07-2014 02:26 AM
Switching back to 17" Wheels from 18" for acceleration feel? bobsacamenoh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-30-2014 08:35 PM
"Buzzing" From behind the steering wheel under hard acceleration husker741 Issues | Warranty | Recalls / TSB 13 06-30-2013 02:18 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 05:52 AM
