Drives: 2014 BRZ
Brief "chirp" sound on acceleration
Hi all,
I've done a bunch of searching, but haven't been able to find much regarding a slight "chirp" sound that comes from the front of the car when I quickly stab the throttle when rev matching or quickly accelerating after shifting. My car is a 2014. Engine mods are OFH and OFT Stage 2 tune. 18.5k miles I can tell you that the noise isn't coming from the clutch, it's not the rear tires chirping, and climate control is off when I've tested it so it's not the AC clutch. It's also not the normal chirping from the fuel pump. The car is still under warranty, but with all of the quirks this chassis has I'd like to know if this is normal or if this is something that I should make a warranty claim on. I don't have a sound clip now, but I could try to record one tonight. Thanks. Last edited by nastynate88; 04-03-2017 at 01:14 PM. |
#2 |
Wes
My flywheel used to chirp in a Mini. It was glazed all to shit
#3 |
Drives: 2015 FR-S
I recently installed a UEL header and OFT stage 2 tune also and noticed the same chirp. It's only at WOT that I hear it though after the car upshifts(Auto).
Figured it was just a new noise to get used to from the header/tune. Pretty sure it's normal: http://www.ft86club.com/forums/showthread.php?t=70903 |
#4 |
Drives: 2014 BRZ
Definitely not a woosh. I'd describe it more like a belt is momentarily slipping for a fraction of a second.
#5 |
Pokemon Master
Drives: 2014 Scion FR-S
Sounds similar to
Start @ :40?
![]() '10 MazdaSpeed 3 Velocity Red Mica - SOLD PDM 2 '14 Scion FR-S MT FireStorm Red STAGE 2 + - FIVE AXIS BODY KIT - HKS DROPIN - INVIDIA N1 - GRUPPE-S UEL- ENKEI LUSSO 18X7.5 +42 - ST COILOVERS |
#6 |
Drives: 2015 FR-S
#7 |
Huge E85 fan!
Drives: 2016 Scion FRS
IMHO you're over-analyzing the noise. It's nothing. Cars make noise
| The Following User Says Thank You to guybo For This Useful Post: | humfrz (04-03-2017) |
#8 |
Yep, Ill have to agree with guybo ....... this time ......
![]() humfrz |
#9 |
Drives: 2014 BRZ
http://www.ft86club.com/forums/showthread.php?p=2565234
Seems this person had a similar issue, but no follow up. |
#10 |
Drives: 2014 BRZ
http://www.ft86club.com/forums/showthread.php?t=62346
Looks like the noise is tip in knock. I don't remember if this was there before the tune or not, but it seems to be what it is |
#11 | |
Drives: scion fr-s
#12 |
Drives: between cars...
#14 |
Drives: 2014 BRZ
| Remote door lock "chirp" | ArtS | Electronics | Audio | NAV | Infotainment | 12 | 09-11-2015 01:35 PM |
| 2015 Series.Blue Engine "Chirp"and 2nd Gear Grind | s30series | Issues | Warranty | Recalls / TSB | 33 | 09-07-2014 02:26 AM |
| Switching back to 17" Wheels from 18" for acceleration feel? | bobsacamenoh | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 08-30-2014 08:35 PM |
| "Buzzing" From behind the steering wheel under hard acceleration | husker741 | Issues | Warranty | Recalls / TSB | 13 | 06-30-2013 02:18 PM |
| Steering wheel/dash "rattle?" upon heavy acceleration? | brett_g | Issues | Warranty | Recalls / TSB | 2 | 08-04-2012 05:52 AM |
