Old 04-03-2017, 11:51 AM   #1
nastynate88
nastynate88's Avatar
Drives: 2014 BRZ
Brief "chirp" sound on acceleration
Hi all,
I've done a bunch of searching, but haven't been able to find much regarding a slight "chirp" sound that comes from the front of the car when I quickly stab the throttle when rev matching or quickly accelerating after shifting.
My car is a 2014. Engine mods are OFH and OFT Stage 2 tune. 18.5k miles
I can tell you that the noise isn't coming from the clutch, it's not the rear tires chirping, and climate control is off when I've tested it so it's not the AC clutch. It's also not the normal chirping from the fuel pump.
The car is still under warranty, but with all of the quirks this chassis has I'd like to know if this is normal or if this is something that I should make a warranty claim on. I don't have a sound clip now, but I could try to record one tonight.
Thanks.
nastynate88 is offline   Reply With Quote
Old 04-03-2017, 11:58 AM   #2
StraightOuttaCanadaEh
Wes
My flywheel used to chirp in a Mini. It was glazed all to shit
Old 04-03-2017, 12:04 PM   #3
Impureclient
Drives: 2015 FR-S
I recently installed a UEL header and OFT stage 2 tune also and noticed the same chirp. It's only at WOT that I hear it though after the car upshifts(Auto).
Figured it was just a new noise to get used to from the header/tune.
Pretty sure it's normal: http://www.ft86club.com/forums/showthread.php?t=70903
Old 04-03-2017, 12:10 PM   #4
nastynate88
Drives: 2014 BRZ
Definitely not a woosh. I'd describe it more like a belt is momentarily slipping for a fraction of a second.
Old 04-03-2017, 12:30 PM   #5
PDM 2
Pokemon Master
PDM 2's Avatar
Drives: 2014 Scion FR-S
Sounds similar to
Start @ :40?
'10 MazdaSpeed 3 Velocity Red Mica - SOLD
PDM 2
'14 Scion FR-S MT FireStorm Red STAGE 2 + - FIVE AXIS BODY KIT - HKS DROPIN - INVIDIA N1 - GRUPPE-S UEL- ENKEI LUSSO 18X7.5 +42 - ST COILOVERS
PDM 2 is offline   Reply With Quote
Old 04-03-2017, 12:33 PM   #6
Impureclient
Drives: 2015 FR-S
Exactly how mine sounds. A kind of squeak, squeal, chirp, turbo blow off sound.
Old 04-03-2017, 12:48 PM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
IMHO you're over-analyzing the noise. It's nothing. Cars make noise
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
humfrz (04-03-2017)
Old 04-03-2017, 01:21 PM   #8
Yep, Ill have to agree with guybo ....... this time ......
Old 04-03-2017, 01:42 PM   #9
nastynate88
Drives: 2014 BRZ
http://www.ft86club.com/forums/showthread.php?p=2565234
Seems this person had a similar issue, but no follow up.
Old 04-03-2017, 01:50 PM   #10
nastynate88
Drives: 2014 BRZ
http://www.ft86club.com/forums/showthread.php?t=62346
Looks like the noise is tip in knock. I don't remember if this was there before the tune or not, but it seems to be what it is
Old 04-03-2017, 02:14 PM   #11
mclovin85
mclovin85's Avatar
Drives: scion fr-s
Hi all,
Thanks.
i sometimes get this noise when i rev match... i hope its not something serious
mclovin85 is offline   Reply With Quote
Old 04-03-2017, 02:25 PM   #12
imnotsureaboutbrz
Drives: between cars...
...Engine mods are OFH and OFT Stage 2 tune. 18.5k miles...The car is still under warranty...
Good luck to ya, but I had a little chuckle when I read this.
imnotsureaboutbrz is offline   Reply With Quote
Old 04-03-2017, 02:29 PM   #13
guybo
Huge E85 fan!
guybo's Avatar
You're finally starting to smarten up.
humfrz (04-03-2017)
Old 04-03-2017, 03:10 PM   #14
nastynate88
Drives: 2014 BRZ
What funny about it? The car is under 3 years old and less than 36,000 miles. Modifying your car doesn't nullify your warranty.
Remote door lock "chirp" ArtS Electronics | Audio | NAV | Infotainment 12 09-11-2015 01:35 PM
2015 Series.Blue Engine "Chirp"and 2nd Gear Grind s30series Issues | Warranty | Recalls / TSB 33 09-07-2014 02:26 AM
Switching back to 17" Wheels from 18" for acceleration feel? bobsacamenoh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-30-2014 08:35 PM
"Buzzing" From behind the steering wheel under hard acceleration husker741 Issues | Warranty | Recalls / TSB 13 06-30-2013 02:18 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 05:52 AM
