go_a_way1
Old 03-28-2017, 08:04 PM   #3417
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Originally Posted by TheWhiteWizard13 View Post
Thanks bro!! That all i needed to know ... Thats the goal, ultimate amount of poke on stock height and when i get bags, hopefully it will sit as flush as possible ... any knowledge about that?
2 inches of drop will do you well. But if you're going for a totally slammed look you'll need 18 x 10 or wider to sit flush with fender.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
TheWhiteWizard13 (04-30-2017)
Old 03-28-2017, 08:12 PM   #3418
churchx
churchx's Avatar
Drives: 2014 GT86
Originally Posted by James The Giant View Post
Its pretty simple, I just like grip. I like taking corners fast too, only I'd rather the rear not slide out on me. I also like the way fat wheels look, sue me lol. If I was racing I would care about minor performance loss, but since Im just driving around normal places, i doubt having a little extra traction out back will suck the fun out of a boosted rwd sports car.
I'd bet $100 it'll pass the doughnut test!!
You're still not getting what me and others were trying to tell. It was not to reduce grip in rear, but to add proportionally in front as much as in rear, to not fsck up handling, hence rear will not slide any more then in your setup going at same speed. We are not telling to get narrower tires in back, but to put same wider width in front too. But i'm giving up tries to get logic through to you. You want to pay to make car worse. Your money, your car.
And .. you'll pay much more to buy again front wheels & tires then $100. Please, don't blame us then for not being convincing enough
swarb (03-29-2017)
Old 03-28-2017, 09:38 PM   #3419
James The Giant
James The Giant's Avatar
Drives: 2013 10 Series Scion Frs
I get it, I just dont care... Again, my car is a daily driver, not a racecar. While i like to have a little fun in the car, Im not pushing the limit enough to care about slight added understeer because of my wheel choice. Its not going to screw anything up on my car, it just wont handle as good as someone who built their whole car around having perfect suspension. I like function, but I like looks too. I got a good deal on a package I like, and I came here to make sure it would fit... I appreciate the advice, but I have enough experience modding cars to know a staggered setup wont hinder 95% of my daily driving.
James The Giant is offline   Reply With Quote
Old 03-29-2017, 01:20 AM   #3420
TheWhiteWizard13
TheWhiteWizard13's Avatar
Drives: 2013 Subaru BRZ with Invidia N1
Thats all good stuff to know, When i get bags im trying to go for that totally slammed look. Now would spacer aid the goal of sitting flush when slammed if i wanted to keep the same wheels? I would only park at slammed height, when driving i would do the 2 inch drop like you said depending on the condition of the road i would be whippin on. Western, Ny streets are garb-salad
TheWhiteWizard13 is offline   Reply With Quote
Old 03-29-2017, 03:48 PM   #3421
Evo.X
Drives: Evo X
Originally Posted by asdf View Post
I have been very happy with my 17x9 +35 wheel + 245/40/17 set up. will be fine with a 1" drop on either springs or coilovers, but it will definitely need some camber dialed in (which nets a positive benefit).
A lot of folks on the forums do run 18s, but I would prefer to stick to 17s (preference in looks/tire sidewall look, tires slightly cheaper as well).
I believe the rpf1s will present clearance issues if you ever want to run a BBK so that may be a consideration. a widely popular option that comes in 17x9+35 (among other sizes that fit would fit well) and will not cost an arm and a leg are the wedssport tc105n wheels
Aw man, doubt he's getting any camber adjustment parts any time soon. How far would he poke at 1-1.5 drop 17x9 +35 245/35-40? Or will that start rubbing already?
Originally Posted by swarb View Post
Yes, 18's are like 19's on a evo. Looks great but excessive weight and tire cost.
17x9 +35 would be the best choice for function and form(in 17"). It won't rub with 245/40. That setup is probably the most common for these cars.
Is that factoring in a drop with no camber adjustment? I'm basing everything off what I saw in the chart so just a little more cautious about getting 17x9 +35 since that's waaay beyond flush according to the chart.
Evo.X is offline   Reply With Quote
Old 03-29-2017, 04:30 PM   #3422
tyler_win_photo
Yeah spacers would help. If you go thick spacers make sure to get the bolt on ones.
Old 03-29-2017, 05:59 PM   #3423
swarb
The chart is for stock height and zero camber.
Everyone's definition of flush is slightly different. Check out this thread and decide for yourself. Camber bolts are like 20bucks.
http://www.ft86club.com/forums/showthread.php?p=832204
Old 03-29-2017, 07:34 PM   #3424
killerham
Drives: 2013 FRS
Will these fit all around? 18x8.5 (ET 40) 5x114.3
230/45/18 tires
killerham is offline   Reply With Quote
Old 03-29-2017, 07:41 PM   #3425
swarb
230/45/18 tires
Our cars are 5x100 and it won't fit.
The Following User Says Thank You to swarb For This Useful Post:
killerham (03-29-2017)
Old 04-01-2017, 03:59 PM   #3426
volbeat
Drives: 13' BRZ
Guys, Im not any good with offset and widt and stuff, so need your help!
9x18 ET 40 on all corners, is it possible?
Wheels in mind is Japan Racing JR3, tires 225/40-18
volbeat is offline   Reply With Quote
Old 04-05-2017, 12:40 PM   #3427
PDM 2
Pokemon Master
PDM 2's Avatar
Drives: 2014 Scion FR-S
Looking at basically the same set-up but offset +30 instead. anybody chime in? But from what i've read through the pages, im sure we will be okay.
Ps. im on stock suspension,
'10 MazdaSpeed 3 Velocity Red Mica - SOLD
PDM 2
'14 Scion FR-S MT FireStorm Red STAGE 2 + - FIVE AXIS BODY KIT - HKS DROPIN - INVIDIA N1 - GRUPPE-S UEL- ENKEI LUSSO 18X7.5 +42 - ST COILOVERS
PDM 2 is offline   Reply With Quote
Old 04-05-2017, 01:29 PM   #3428
_Silent_
Drives: Subaru BRZ
Will Forgestar M14 18x8.5 +38 245/35-18 MPSS, Fit with just FA 500 Coilovers?
_Silent_ is offline   Reply With Quote
Old 04-06-2017, 10:38 AM   #3429
volbeat
Drives: 13' BRZ
I've ordered the wheels, so i guess we will find out soon enough.
Will post pictures in a feew weeks when i recieve them.
Old 04-06-2017, 06:24 PM   #3430
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Its tight to the inner struits, but with 225 tires it should work
Will work, but will be about 1cm outside the fenders
Will fit fine and also look very good
Killerbee is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
