Old 05-06-2014, 10:54 PM   #113
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
Originally Posted by wparsons View Post
This has already been covered in the thread, but it's not an issue below 90%... the app assumes if the TP drops more than ~5% from the peak value it's no longer at WOT. I've messaged the guy that wrote it about this, but the easy solution is to just increase the TP values to be within 5% of the peak (I normally just set them all to 100).
Thanks. I changed mine to 98% so it all worked out. Quick and easy fix. I always read through so many pages of material on here and of course the one time I don't, it's already been discussed...
Sent from my HTC One using Tapatalk
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
The Following User Says Thank You to gabeg86 For This Useful Post:
wparsons (05-07-2014)
Old 07-21-2014, 02:39 AM   #114
DC2R
Drives: 2014 Scion FR-S
how the hell are you guys doing 4th gear redline pulls on the street iirc 3rd gear redline pulls bring you up to like 90 mph.....::not a cop::
DC2R is offline   Reply With Quote
Old 03-22-2017, 07:21 PM   #115
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Hey guys, sorry to bring back a long dead thread, but I just got OFT and want to learn more about how to tune and what to look for. So I'm looking o get some input on my values and VD graph to see if there is anything I should tweak in romraider, as I'm a tuning newb. Thanks
http://www.datazap.me/u/gordszenith/...data=1-2-3-5-7
Btw I'm running 93 octane map and fuel.
Also as a side note, my AFR doesn't show up in VD even though I've changed the name like instructed.
EDIT: I was able to add in the AFR for each run. However, I have a question now, why would 91 make more power and torque than the 93? is it because its been more refined? @Shiv@Openflash @steve99
Gords_zenith is offline   Reply With Quote
Old 03-25-2017, 03:39 AM   #116
steve99
Drives: FT86
no idea why 91 suposedly made more power, maybe data error or jist variation in temps or some other factor
Old 03-25-2017, 06:55 AM   #117
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I don't know about anyone else, but there's this 4.8 mi long bridge on the way to work..... it has a big radar-deflecting hump about halfway....
guybo is offline   Reply With Quote
Old 03-27-2017, 01:47 AM   #118
Gords_zenith
I was thinking the same. So to eliminate I've flashed back to 91 and will post that log tomorrow. But for now here the data logs that I used for VD. I was also hoping someone could shed some insight on them, and why the 93 knocks so bad, as I'm fairly new to this.
93 tune 94 octane and cold weather. It knocks a lot and cuts the timing.
http://www.datazap.me/u/gordszenith/...t?log=0&data=1
91 tune with 93 octane.
http://www.datazap.me/u/gordszenith/...0&data=1-3-5-6
Thanks.
Old 03-27-2017, 03:29 AM   #119
steve99
Drives: FT86
Thanks.
its only minor knock -0.6 and iam is still 1
next time log afr instead of widebandafr as thats for an aem wideband sensor.
the only diff between 91/93 tune is ignition timing over 5000 rpm
Teseo (03-27-2017)
Old 03-27-2017, 08:35 AM   #120
Gords_zenith
Hey thanks for looking into that.....sorry if you saw this before, I Just finished nights.
I do have AFR logged it's just named as Lambda (Bank1)(AFR) so it would work in VD. Also, I have a KN drop in filter, would that affect the LTFT so it's more negative? I also note that the induction noise is a lot more at 4000 RPM than with 91......thoughts?
Old 03-27-2017, 12:39 PM   #121
aagun
Drives: 86
i did test before . lean my tune . 13.0 at wot huge power . iam drop to 0.88 and fbkc -3.0+
aagun is offline   Reply With Quote
Old 03-27-2017, 06:23 PM   #122
steve99
Drives: FT86
Strange the induction noise arround4k would be differnet between 91\93 tunes, this is generally due to cam timing which should be same. Maybe check the tune tables to see the vvt intake and exhaust tables are same
Old 03-28-2017, 08:53 PM   #123
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
Here is what I got after a run in 3rd on a flat highway from about 3.5K rpm. I feel like its reading a little high as I have a catted UEL header. It's interesting to see how the torque dip has been flattened out a good bit though if it's accurate.
Mods are: Apexi air filter, Perrin inlet hose, JDL Catted UEL header, Perrin overpipe, catted front pipe, and 2.5" catback. And then the OFT stage 2 tune.
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
The Following User Says Thank You to BFIFE22 For This Useful Post:
Vin (03-29-2017)
Data Logs! Post them here. feldy Software Tuning 2161 12-24-2025 01:17 AM
Anyone help interpreting data logs? cuddefred Engine, Exhaust, Transmission 8 10-11-2013 07:30 PM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
