Old 03-06-2017, 04:47 PM   #15
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
It will be noisy as hell.
Old 03-06-2017, 10:03 PM   #16
forevergone
Drives: FRS
More cabin noise but that's about it.
forevergone is offline   Reply With Quote
Old 03-06-2017, 10:56 PM   #17
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by Cubix View Post
I just think it looks cool. Noone sits back there anyways, but if it's unsafe I'm not gonna do it.
And unsafe... Don't forget how unsafe it is.
The Following User Says Thank You to Andrew025 For This Useful Post:
Yardjass (03-07-2017)
Old 03-06-2017, 11:49 PM   #18
BlueLine
Drives: 2013 Rally Blue w/Bronze wheels MT
Not exactly the same league as pulling the seat and side panels and leaving it all open. If I didn't have to use the seats every now and then I would be looking into that delete. It is pretty.
I agree that's the same situation I am in. However if he wants to do it this doesn't scream I trashed my car trying to look like something I am not
BlueLine is offline   Reply With Quote
Old 03-07-2017, 12:44 AM   #19
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
+1000 on that seat delete.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Kestrel is offline   Reply With Quote
Old 03-07-2017, 12:55 AM   #20
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
That's the delete kit I have. It was my first mod. I like it, looks real nice. The only problem is you can't put any weight on it, that's why I only clean my back window once a year.
Old 03-07-2017, 02:50 AM   #21
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Makes me wonder if it'd be better to just buy some acrylic/plywood, mlv, fabric, and do this yourself. At least then you could make it support weight and maintain some sort of noise control...
Never knew that kit couldnt support any weight at all, especially for the price of the kit.
Old 03-07-2017, 02:56 AM   #22
reni
Nobody beats the B[I|R]Z
reni's Avatar
Drives: shopping cart i stole from walmart
I wanted to strip the rear backseats and speaker panels for the summer because its a racecar (this part is sarcasm). I don't want to remove the curtain airbags though, and I'm worried that the airbag might go off if someone accidentally punches a sensor.
Are airbag sensors smart enough to not go off in that case? And is it the yellow plug near the speakers?
I can't believe there are still people that think this is how airbags work
reni is offline   Reply With Quote
Old 03-07-2017, 03:20 AM   #23
EnoOnraefi
EnoOnraefi's Avatar
Drives: MY17 Asphalt 86
Zeal86 has a pretty badass looking rear seat delete project going on in his build thread... If you have the ability to make something yourself you might check that out HERE.
EnoOnraefi is offline   Reply With Quote
Old 03-07-2017, 10:59 AM   #24
Sapphireho
Famous Potatoes
Sapphireho's Avatar
It cuts out noise quite well. The bottoms of the flat parts have sound mat glued on and it comes with a couple more sheets of sound material to lay down. Believe me, it is a lot louder with it out. I used hard fasteners to put the bottom 3 pieces together. I have it so 2 wing nuts removes the entire bottom piece when I want in a couple seconds. It it very light weight. I would imagine something made with wood would be quite heavy.
I like it. If you didn't know, you would think the car came that way.
Conman (07-05-2019)
Old 03-07-2017, 01:16 PM   #25
PandaSPUR
PandaSPUR's Avatar
lol yea. But to be fair, it could still be risky if someone who decided to sit back there shorted a connection to the airbag. I think?
Old 03-07-2017, 06:45 PM   #26
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Is it safe to run with a stripped interior?
Oh, helz noe.
That's worse than running with scissors!
Old 03-07-2017, 09:22 PM   #27
The connections are well secured inside clips and not readily accessible. Besides if there is no seat or seat belts back there then there should not be any passengers anyway. If there are then them somehow managing to set off the airbags would be the least of your worries anyway.
Old 03-08-2017, 01:33 PM   #28
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
omagosh
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Oil filter threading stripped davtbaum Issues | Warranty | Recalls / TSB 53 06-03-2017 02:10 PM
Stripped a Stud -- Safe to Drive? carczar87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 12-07-2016 01:46 PM
Stripped strut rod, need suggestions switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-21-2016 07:25 PM
Wheel bolt stripped 2pointSLOW86 Issues | Warranty | Recalls / TSB 23 10-13-2014 03:29 AM
Have you stripped some weight off your FRS? gt8613 Scion FR-S / Toyota 86 GT86 General Forum 39 08-20-2013 03:11 PM
