| Software Tuning Discuss all software tuning topics. |
Drives: Toyota 86
OFT VVT Intake log values are abnormal.
Hi,
Recently I found that OFT shows abnormal VVT intake values. See this video. Do you have same symptom? I've PM'd Shiv but no reply yet. |
#2 |
Drives: 86
normal
it takes same time to reactive |
#3 |
Drives: Toyota 86
I don't think 100 degree is normal for VVT Intake value.
Do you? The values are jumping from 0 to 100 or 50. Previously it hasn't been like that. I've used OFT over two years and done VVT optimization using vgi's tool many times. |
#4 |
Drives: 86
one minute
thats not normal as the rom the value of 100 is ERROR . that can not read by ecu . if so the AVCS will jump to AVCS error mode if there are no cel . then everything on engine side is ok @steve99 can help here |
#5 |
Drives: Toyota 86
No CEL.
So I suspect an OFT bug (recently added). VVT exhaust values are looking good as before. My colleague is also experienced the same symptom. Last edited by makinen; 03-07-2017 at 07:51 AM. |
#6 |
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Are you connecting the OFT directly to the OBD port, or do you have an extension cable/Y cable?
#7 |
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
Did you try unplugging the tablet and plugging it back in?
#8 |
Drives: Toyota 86
#9 |
Drives: Toyota 86
#10 | |
For me, logging with the OFT and my P3Cars Gauge both connected to the OBD port at the same time, i would get reading errors like that. When both try to read from the same port at the same time, you get an error reading and it displays the lowest value for a split of a second. |
#11 | |
Drives: Toyota 86
I've tried with only OFT connected but no good. Only VVT intake values are odd. I'm using A01E rom. Maybe only that CAL ID has an issue. |
#12 |
Drives: 2016 BRZ, 94 Integra GSR
I just updated my off, and its doing the same thing. I switched it to "intake vvt at" and it reads normal values.
#13 | ||
Drives: FT86
It will almost certainly be a logging issue with your rom calid or an error in the latest OFT update/template file |
| RE71R abnormal wear? | BR-ZED | Tracking / Autocross / HPDE / Drifting | 13 | 03-23-2016 12:17 AM |
| Abnormal rear brake wear 2013 w/ 31,700 miles | Gen3MR2 | Issues | Warranty | Recalls / TSB | 13 | 04-02-2015 02:44 PM |
| Abnormal throttle noise | RunHachi | Issues | Warranty | Recalls / TSB | 3 | 01-02-2015 09:35 PM |
| Abnormal noise when throttle blip or WOT shifting | evo4g63 | Issues | Warranty | Recalls / TSB | 48 | 10-16-2014 09:42 AM |
| Fuel trims abnormal after cleaning intake. | feldy | Engine, Exhaust, Transmission | 8 | 04-16-2014 05:48 PM |
