Old 03-07-2017, 02:18 AM   #1
makinen
makinen's Avatar
Drives: Toyota 86
OFT VVT Intake log values are abnormal.
Hi,
Recently I found that OFT shows abnormal VVT intake values.
See this video.
Do you have same symptom?
I've PM'd Shiv but no reply yet.
makinen is offline   Reply With Quote
Old 03-07-2017, 02:42 AM   #2
aagun
Drives: 86
normal
it takes same time to reactive
aagun is offline   Reply With Quote
Old 03-07-2017, 03:02 AM   #3
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by aagun View Post
normal
I don't think 100 degree is normal for VVT Intake value.
Do you?
The values are jumping from 0 to 100 or 50.
Previously it hasn't been like that.
I've used OFT over two years and done VVT optimization using vgi's tool many times.
Old 03-07-2017, 07:15 AM   #4
aagun
Drives: 86
one minute
thats not normal
as the rom the value of 100 is ERROR . that can not read by ecu . if so the AVCS will jump to AVCS error mode
if there are no cel . then everything on engine side is ok
@steve99 can help here
Old 03-07-2017, 07:31 AM   #5
makinen
makinen's Avatar
Drives: Toyota 86
No CEL.
So I suspect an OFT bug (recently added).
VVT exhaust values are looking good as before.
My colleague is also experienced the same symptom.
Old 03-07-2017, 12:04 PM   #6
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Are you connecting the OFT directly to the OBD port, or do you have an extension cable/Y cable?
tato.valverde is offline   Reply With Quote
Old 03-07-2017, 12:07 PM   #7
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Did you try unplugging the tablet and plugging it back in?
murdoc is offline   Reply With Quote
Old 03-07-2017, 07:18 PM   #8
makinen
makinen's Avatar
Drives: Toyota 86
I connected 86 nanny first to the OBD port and connected OFT after that.
But before, to say, Mar. 4, OFT logged without an issue.
Old 03-07-2017, 07:19 PM   #9
makinen
makinen's Avatar
Drives: Toyota 86
Already done several times, no help.
Old 03-08-2017, 03:41 PM   #10
tato.valverde
So they're both connected at the same time?
For me, logging with the OFT and my P3Cars Gauge both connected to the OBD port at the same time, i would get reading errors like that. When both try to read from the same port at the same time, you get an error reading and it displays the lowest value for a split of a second.
Old 03-10-2017, 10:14 AM   #11
makinen
makinen's Avatar
Drives: Toyota 86
Both connected but 86nanny is not a reading device but a writing(sending pedal dance command) device.
I've tried with only OFT connected but no good.
Only VVT intake values are odd.
Name:  odd vvt intake.png
I'm using A01E rom. Maybe only that CAL ID has an issue.
Old 03-21-2017, 01:12 AM   #12
Hyperblue302
Hyperblue302's Avatar
Drives: 2016 BRZ, 94 Integra GSR
I just updated my off, and its doing the same thing. I switched it to "intake vvt at" and it reads normal values.
Hyperblue302 is offline   Reply With Quote
Old 03-21-2017, 09:26 AM   #13
steve99
Drives: FT86
Hi,
See this video.
It will almost certainly be a logging issue with your rom calid or an error in the latest OFT update/template file
Old 03-21-2017, 09:34 AM   #14
steve99
Drives: FT86
Hi,
See this video.
best email shiv or message him on facebook, I don't think he responds to PM on this forum
makinen (03-21-2017)
RE71R abnormal wear? BR-ZED Tracking / Autocross / HPDE / Drifting 13 03-23-2016 12:17 AM
Abnormal rear brake wear 2013 w/ 31,700 miles Gen3MR2 Issues | Warranty | Recalls / TSB 13 04-02-2015 02:44 PM
Abnormal throttle noise RunHachi Issues | Warranty | Recalls / TSB 3 01-02-2015 09:35 PM
Abnormal noise when throttle blip or WOT shifting evo4g63 Issues | Warranty | Recalls / TSB 48 10-16-2014 09:42 AM
Fuel trims abnormal after cleaning intake. feldy Engine, Exhaust, Transmission 8 04-16-2014 05:48 PM
