Old 02-14-2017, 09:52 PM   #43
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Those numbers look fantastic. How does the car hold up on heat soak? The super short runners seem to really help out.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 02-14-2017, 10:00 PM   #44
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Its going to be a handfull thats for sure! will have a few boost settings so its not going to be dailyed at 300 (it could) more for my own safety then the engine not being able to.
I honestly will have to test it and see. Its been 35+ here with like 80% humidity or something for the last 4 odd weeks it was on the dyno all day. We actually stoped cause it was just to hot yesterday and around 296rwkw and fired it up early hours before it got insane and it already shot out the 303 number. Boost has been brought on not as sharp as it can simply cause trans not holding.
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
Stimmed is offline   Reply With Quote
Old 02-15-2017, 12:10 AM   #45
Stimmed
Stimmed's Avatar
Drives: Toyota 86
https://www.facebook.com/tunedbycoyo...1281446276712/
The Following User Says Thank You to Stimmed For This Useful Post:
Yoda (02-15-2017)
Old 02-15-2017, 07:31 AM   #46
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Damn, that torque curve looks amazing!
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Stimmed (02-15-2017)
Old 02-23-2017, 09:00 AM   #47
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Originally Posted by Stimmed View Post
Hahah dosent anything fit on a honda?? :P
Turbo is a 3582 its low mounted up the front but you litterally cant see it. Even looking in the engine bay you may get a glimpse of it but you have to really get in close its hidden away nicely.
ATM the software is BRZEdit But I think Tony might be looking at ecutek in the near future but not to sure.
Thats actually the heat exchanger at the front. It runs a W2A setup. Which is sitting under that "Coyoda" labled box at the front of the engine bay. The intake they used to use the standard one so it looked even more stock but issues were to hard to get oil lines in for oil coolers etc. So now there custom making that intake the pod sits in the bumper. Harder to change and check but much more room in the engine bay it self.
Keep in mind this is on an auto. I was going with a 3076 but Tony/Al said with the auto it will mask a bit of the lag anyway and they were very keen to see if they could fit the new bigger turbo down there....and they did!.
Only issue we are worried about is the auto not handling enough power. I have a spare to be built if needed but we will play it by ear. The setup is making alot of torque it should be a blast.
Hope that answered most questions just quote again if I missed any will try and reply
hmmmm brzedit.. n 3076.. u got my attention
stevo_12v is offline   Reply With Quote
Old 02-24-2017, 01:04 AM   #48
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Yeah on a Manual and and the right rear housing 3076 will still get 300rwkw even on Tonys dyno. If the auto trans held more we woulda pushed the 3582 more but its no big deal im more then happy how it is and running. Auto trans seems to be sapping about 10% odd in power from engine to wheels.
But god it flys . Still only running on low boost till im a bit more used to the power. Then ill swtich it up
Old 02-24-2017, 08:51 AM   #49
stevo_12v
What 3076 is it? I heard they use their own 'coyoda' turbos?
Do you know if it would be the equivalent to the new Garrett GEN II GTX3076R's?
https://turbobygarrett.com/turbobyga...tx3076r-gen-ii
Old 02-24-2017, 05:17 PM   #50
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Hey mate,
Im not sure exactly how it works with there turbo. But its theirs yes but based on the 3076. And a smaller one for the street kit. Im not sure how it compares exactly would need to ask them more for that one sorry.
Old 04-01-2017, 01:33 AM   #51
coyote
coyote's Avatar
Drives: Slowly
Just became aware of this thread. Happy to answer any questions, but be warned I won't be on here much and I can be a grumpy prick. If there's enough interest I may be able to get Turbo Yoda to register also.
coyote is offline   Reply With Quote
Old 04-01-2017, 12:07 PM   #52
Cybmx
Drives: 2016 Hyperblue Brz
Will this be available in the US soon?
Cybmx is offline   Reply With Quote
Old 04-01-2017, 09:41 PM   #53
coyote
coyote's Avatar
Drives: Slowly
The Coyoda turbo systems will be available in the USA later this year.
Old 04-01-2017, 10:10 PM   #54
GsxrMe
GsxrMe's Avatar
Wait wait wait. Who cares who makes the turbo housings. What and who makes the core? Last thing is someone pushing 400hp on a cheap mystery core that comes apart and eats a motor. Are we talking garrett core or ebay china, china maybe?
2014 Subaru BRZ
Old 04-01-2017, 10:27 PM   #55
coyote
coyote's Avatar
Drives: Slowly
Stimmed's car has an FP Black turbo. FP used to use Garrett cores, but switched to Xona Rotor.
Myself and Turbo Yoda tested a massive combination of cores and housings (including Garrett, of which he is a dealer) during the prototyping process to determine what we would put our brand on.
There are many turbo kits for these cars that are China specials. The Coyoda turbo systems do not fit into that category.
The Following User Says Thank You to coyote For This Useful Post:
sato (04-02-2017)
Old 04-16-2017, 12:52 PM   #56
86raus
86raus's Avatar
Drives: 2017 blue toyota 76
Why did you go w2a over a2a?. What are the benefits /negatives you have found on the 86 platform coyote.
Sent from my SM-G935F using Tapatalk
86raus is offline   Reply With Quote
MAPerformance turbo kit thread! MAPerformance Forced Induction 277 02-14-2023 03:49 PM
JDL turbo kit thread diss7 Forced Induction 352 02-03-2019 02:04 AM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Turbo BRZ build thread IBill4You Member's Car Journals 6 03-13-2017 06:34 PM
FINDING SBD TURBO KIT THREAD myioz86 Forced Induction 2 01-21-2015 12:00 AM
