| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#2115 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
+44 is pretty tame for the rear! you will still rub the bumper tab, let that shave itself to be honest. with a roll i ran 18x9.5 +40 with 265/35 MPSS. i had -1.8 front and -1.4 rear. very mild...also don't forget to ask them to toe in the rear a bit.
#2116 | |
Drives: 2013 BRZ black
#2117 | |
Drives: Subaru BRZ 2017 (almost)
![]() Sent from my Nexus 6P using Tapatalk |
#2118 |
Drives: WRB Limited BRZ
SPC LCAs came in!
I was looking at @Lust alignment settings and I think I really like it, looks perfect for a street car! I'm also really lovin his TE37 |
#2119 |
Drives: 2017 Subaru BRZ Crystal White Pearl
Got to take my car for a pretty good drive this past weekend. Handles so much better than stock. Had the usual minor rubbing on the rear bumper tab. Front only rubs at full lock. So I installed velox steering rack limiters.
18x9.5 +40 265 35 18 MPSS Alignment specs: Lowered ~1.5 inches all around Camber -1.8 front and back Toe .08 front and back Rolled front fender near sidemarker. |
#2120 | |
Drives: 2014 Scion FRS (Asphalt)
Personally I run Cusco, no complaints personally except that alignments do take a while with them. |
#2121 |
Drives: 2017 Toyota 86
I only have a couple pics so far, but:
Wheels/ Tires: Volk Racing TE37RT in mag blue (18x10 +44) PoweredByMax 5mm spacer in the front and rear 255/35/18 Federal RS-RR Suspension: PoweredByMax competition coilovers PoweredByMax rear lower control arms PoweredByMax rear toe arms Alignment / Coilover Specs: Front - 1.8 camber, 0 toe, 6.2 caster Rear - 1.2 camber, 0.1 toe Front is maxed out with all collars in, rear has tons of room to go. The rear coilover is mounted on the bottom hole of the lower control arm mount. 0 preload all around. Fenders are rolled all around and the ebrake bracket had to be bent for clearance. Not sure if I would've been able to clear the fenders without the roll, didn't try ![]() ![]() ![]()
#2122 |
Drives: 2014 Subaru Brz
#2123 | |
Drives: '24 GR86
#2124 |
Drives: Black MT LMT BRZ
Sooo 18x9.5 +45 255/35/18 on about a 1.5 to 2 in drop should be fine? No rolling fenders. Any rubbing should eventually rub itself out. I just order Wedssport wheels last night and am tryingto find something nice to wrap them in. So far I'm set 255s from reading this thread
#2125 | |
stock struts it will not fit. 255/35 is a good choice. 2 inch drop it will be a little tight in the front when turning. |
#2126 |
#2127 |
Drives: MY17 Asphalt 86
#2128 | |
Drives: 15 scion frs
Sent from my SM-G935P using Tapatalk
2015 Scion FR-S-hot lava 6MT Perrin cai magnaflow cbe EFI LOGICS tuned 193whp
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
