P000A and P0011
Today I started my car and got P000A and P0011 codes and the track control light was on and the Cel light. Car didnt seem to run different. I cleared the codes and restarted the car and it didnt come back in the 5 minutes I let it run for. Should I be worried. I saw some stuff on the net and I think i read there is a TSB for the codes. Any info is appreciated.
#2 |
I'd suggest you take it out and drive it around for a while.
If the codes don't come back, I'd just chalk it up to an engine hiccup and not worry about it. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Riftur (02-12-2017) |
#3 |
Drives: FT86
Yeah their cam position correlation codes
have a look at the tsb section for avcs, rough idle, cam position idle instability tsb,s theirs a few unfortunatly difficult to diagnose down to a single compent. http://www.ft86club.com/forums/showthread.php?t=21868 might be a simple as an ecu reflash or cam sensor shim, or require cam sproket actuator oil control valves or even new ecu hardware . |
| The Following User Says Thank You to steve99 For This Useful Post: | Riftur (02-13-2017) |
#4 |
Drives: 2015 FR-S
I've been dealing with P0000B since I bought my car (MY15, used)
It comes on, triggers limp mode like yours, clears itself in a couple ignition cycles. Last dealer work replaced the ECU but the code keeps coming back, just less often. At this point I pretty much ignore it and let it go away on it's own. I might take it back to dealer near end of warranty to see if they can clear it for good. |
#5 | |
Drives: FT86
#6 |
Drives: 2013 Subaru BRZ
P000B was an oil control actuator for me. P0016 came up about 4 months later.
| Cylinder Head Assemblies causing P000A & P000C? | SoundsOfTheUniverse | Issues | Warranty | Recalls / TSB | 3 | 01-23-2017 06:37 PM |
| DTC: P0335, P0011, P0345, P0340 | SolderGlob | Issues | Warranty | Recalls / TSB | 8 | 01-13-2017 02:37 PM |
| Considering buying a lemon buyback BRZ, have repair history (P000A and P0011 codes) | ZDan | Issues | Warranty | Recalls / TSB | 21 | 02-19-2016 03:51 PM |
| P000A AVCS check engline light? | cookiesowns | Issues | Warranty | Recalls / TSB | 4 | 10-24-2015 02:48 AM |
