| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#3292 |
Drives: 2014 Firestorm FRS
I'm thinking about getting Rota Grids 18x8.5 et44 with 235/35/18 squared, lowered on RSR super down springs and whiteline front camber bolts. Will that work without any rubbing or other issues? Also could I do 245 all around if I decided to?
#3293 | |
With that size, you are reducing inside clearance by about 15mm. Go under the car and check the front spring perch clearance and you will have your answer. |
#3294 | |
Drives: 2013 Scion FR-S 10 Series
Here's a quick comparison of the factory tire size versus the three tires sizes you had suggested: Last edited by RJasonKlein; 02-01-2017 at 08:45 PM. Reason: Corrected a typographical error. |
#3295 | |
You have to look at the specs on the specific tire. I can't find 245/35 for those tires on tire rack. Only 255/35 and the other sizes mentioned. The 235 is measured on a 8.5" wheel, while the 225 is on a 8". 235 fits better on the wheel, 225 fits better for the car. I'd go with the 225/40 for a few reasons, smaller diameter both for acceleration, lap times, nimbleness, looks(not too tall). Tire rack tested a while back and 225's for lap times, and bigger for ultimate grip(more g's) like slalom or skid pad(like autocross). re71r's are a lot of tire for the street(another reason for 225). They would probably heat cycle out before they wear out, but that does not matter much if you aren't chasing lap times. edit- 245's wont rub unless mcs coils are wide like stock suspension. |
| The Following 2 Users Say Thank You to swarb For This Useful Post: | RJasonKlein (02-01-2017), Teseo (02-09-2017) |
#3296 |
Drives: 2016 BRZ
I'm looking to order the following:
Front - 18 x 8.5 +38 wrapped in 225/40/18 Back - 18 x 9.5 +35 wrapped in 255/35/18 I'm currently on stock suspension. Will I run into any rubbing / clearance issues on stock struts? Considering buying ST Coilovers in the future - likely a 1" drop. Will this set up work? I appreciate the help |
#3297 | |
Drives: Subaru BRZ 2017 (almost)
Sent from my Nexus 6P using Tapatalk |
#3298 |
Drives: 13 FR-S
I've searched all over and can't find an answer to this, so we'll see if my course of thought is correct.
I have a set of 18x9" Motegis left over from my old RX-8 that I'd like to use with my FR-S, I have 245/40/18 PSS tires on them. Problem is (as you probably guessed) the bolt patterns are different. I was considering bolt-on spacer/adapters, and it seems I can find 15mm and 25mm varieties. The wheels are however +35 offset and I assume the spacers would bring me to +20/+10 respectively. Am I going to have issues with fender rub/excessive wheel poke where suspension travel would cause an issue? Edit: Car is bone stock. For now. |
#3299 | |
Drives: 2014 Subaru BRZ
you'll be at +50 effectively , I think you'll have serious poke issues |
#3300 | |
Drives: 13 FR-S
Either way, simulating with the auto fitment calculator I found stickied I found out that even if I'm right (+50 sinks in more) and I have a combined +10, the wheel shouldn't poke too far.
#3301 | |
Forget everything i said in my first reply... with 15mm spacer your offset is going to be +10 effectively, Still poke issues. The red line represents your fender.
#3302 |
Drives: Too fast
Hi guys,
Will it fit rub the shock and coil....can't find a definite answer. 17x8 +45 on 255/40/17, stock suspension, camber maxed out on SPC bolt down + crashbolt upper hole. Thanks. |
#3303 |
255 on an 8 in. wheel?
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
#3304 |
Drives: Too fast
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
