Old 02-03-2017, 10:56 PM   #15
Bjack21
Drives: 2013 scion frs
im in the process of it now. i just took out my passenger side wheel.. will update..
Bjack21 is offline   Reply With Quote
Old 02-03-2017, 11:16 PM   #16
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
PNW-BRZ is offline   Reply With Quote
The Following User Says Thank You to PNW-BRZ For This Useful Post:
Ultramaroon (02-04-2017)
Old 02-03-2017, 11:20 PM   #17
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
"How hard can it be?"
canyons is offline   Reply With Quote
Old 02-04-2017, 01:34 AM   #18
Originally Posted by Bjack21 View Post
Right well i removed the wheel liners and had access to the left bottom bay area. well the good is that its still attached to the latch. the bad is no matter how hard i pull using a vice grip its still unlatched. oh and the air box is blocking the path to the latch so yea..
Did you have someone else push down on the hood while you're trying to pull the cable ... ??
Sorry, I have to ask ....... you are pulling on the cable inside the cable housing and not the cable housing itself ...... ??
Old 02-04-2017, 01:40 AM   #19
Originally Posted by PNW-BRZ View Post
Yep, a P-38 ...... our light Al hood would be a piece of cake for it .....
Old 02-05-2017, 04:28 PM   #20
chipmcdonald
Drives: 2000 Celica GT
Ok, so how do we FIX this problem?
Seems like there should be a grommet/nut ala bicycle brakes to tighten the cable, but there isn't.
Is it the fault of the spring, or the cable? I presume it's the cable being stretched. This is immensely annoying since I just came from a 2000 Celica that had the same exact problem and now my BRZ needs two people to open the hood!
Ahrghh.
chipmcdonald is offline   Reply With Quote
Old 02-06-2017, 02:19 AM   #21
Ahrghh.
Fer cryen out loud, folks, it's a mechanical hood latch ...... they have been around for years! It's not some new fangled ECU controlled piece of rocket science!
Sorry ...... I must have forgot one of ma meds this morning ......
chipmcdonald, what I would do if I were you, would be to first look at the hood latch piece that hangs down from the hood. Is it straight..?? If not, tap it with a hammer till it is. Are the two bolts that hold it in place tight .. ?? If not, tighten them. Now, take a smidgeon of heavy waxy type stuff (like door ease) and place it on the bottom of the metal hoop (where the latch hits it).
Now, I suggest that you make sure the 3 bolts an the latch mechanism are tight. Squirt some WD-40 or silicone spray on the moving parts of the latch mechanism.
Pull the cable a few times with the hood open.
Now, does it work better .... ??
Come back ........
Old 02-06-2017, 09:01 AM   #22
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
Make sure you lube the hood latch when you get it open too. I always wondered why my hand gets all greasy every time I open my hood, and if all of these cars just came that way. Now I'm guessing the previous owner had this problem at some point.
Yardjass is offline   Reply With Quote
An alternate to OEM Audio + that's actually affordable BMHumanic Electronics | Audio | NAV | Infotainment 24 02-28-2014 07:28 PM
DIY - Alternate Hood Prop F1point4 DIY (Do-It-Yourself) Guides 13 03-20-2013 11:22 PM
Injen installed, open/closed hood dynoed Bahraini86 Engine, Exhaust, Transmission 55 02-15-2013 12:24 AM
Alternate car? ngabdala Other Vehicles & General Automotive Discussions 35 05-18-2012 02:09 PM
