Car not starting on first turn of key (not even cranking)
So for 3 days now when the car is cold I turn the key and nothing happens (no cranking or anything). I turn the key off and back on and it starts right up. My car usually starts right up on first try. I dont think its the battery since it starts right up when I turn it the second time. Any clue? Also its a automatic.
#2 | |
#3 |
#4 |
OK sounds silly but try replacing the battery in your key. If it is low it may be taking the disabler a bit to grab the signal. Had that issue with my wife's car.
#5 |
#6 |
Also, you may try nudging the shift lever while it's in the park position.
humfrz |
#7 | |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Had a friend that I sold a Kia Rio to years ago. she called me in a panic one day, saying she was having trouble starting the car. Turns out something was jammed in her shifter, not allowing the car to go fully into park. Any automatic car, of course, has to be in "park" or "neutral" in order to start. The parking pin was going in, allowing the car to actually "park" and not roll away, but the sensor in the shifter assembly was not registering the shifter as being in the "park" position, thus telling the computer to not allow the car to start.
@bpennerz
| The Following User Says Thank You to SLVRSRFR For This Useful Post: | humfrz (01-31-2017) |
#8 |
Drives: 2013 Firestorm FR-S
Tighten up all the connections on your battery too.
#9 |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
#10 |
...Just add nauseum
Drives: 2003 (AP1) S2000
Let me make a wild guess...
This happens when you get in, turn the key from full off, all the way to start immediately without pausing. Nothing happens. Release to "ON" and try again, and it fires up immediately... If I am correct, then I had your exact same problem, except on an MT car. I've looked over the starting circuit thoroughly, and all I can say is either you have a sticky relay or a bad battery. Here's the justification. Unfortunately, on this car, the ground path for the start relay doesn't go straight to the battery, it vanishes into the ECM at pin 26, and then goes god-knows-where. We like to call ECU's "logic boxes" in my field... And they make troubleshooting a ROYAL B*TCH. Either way, there is undoubtedly start logic in the ECM that controls this ground. if you close the contacts for the two start switches in the key switch before all the other relays close and everything is powered, nothing happens. There is start-inhibiting logic somewhere in the ECU... Pity there's no documentation of any kind... Sigh, logic boxes. All it took to solve my problem was pausing a half-second at "ON" before turning the key all the way to "Start"... But it was irritating, because I didn't have to do that when the car was new. Charging the battery made the problem go away for a while, and I didn't want to start chasing relays. Anyway, If your battery is older, and the charge retention has gotten worse, and the cold start voltage is down, it may not have the initial "kick" to close all the relays in the fraction of a second that it takes you to rotate the key all the way from off to start. In older cars, it didn't matter, because the key switch went straight to ground, but in this car it doesn't... For example, on an old MT car, if you turn the key to "START" first, and then depress the clutch, as soon as the clutch bottoms out the engine will crank, because the clutch switch completes the starting circuit. BUT on the FRS, you do the same thing, and nothing happens. Start is inhibited by the ECU because it wasn't in a "ready" condition when the key closed the "Start" switches. On your car, you have no clutch switch, you have a neutral inhibitor relay in the AT shifter which completes the same logic circuit, but it's the same concept. The TL : DR here is it's going to be hard or impossible to determine exactly what the problem is. Try charging your battery and see what happens.
There are many ways to displace.
-Spartarus |
#11 | |
#12 | |
#13 | |
Edit: Also I want to say thank you Tcoat for always trying to help everyone on this site. Your always the first to reply and try to help everyone. We are lucky to have you. |
#14 | |
Have you had the RPM TSB done? It is a simple reflash of the ECU. http://www.ft86club.com/forums/attac...1&d=1386706237
| cranking noise when steering? | dad&sonFRS | Issues | Warranty | Recalls / TSB | 27 | 06-10-2019 09:04 PM |
| CELs and not cranking | 86 driver | Issues | Warranty | Recalls / TSB | 8 | 09-28-2017 02:08 PM |
| Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 11:40 PM |
| Steering wheel issue---left turn lighter than right turn!!! | xingxingtjf | Issues | Warranty | Recalls / TSB | 12 | 10-14-2015 07:47 PM |
| Ethanol Vs Gas Cranking | Luckrider | Software Tuning | 2 | 01-25-2014 09:44 PM |
