Old 01-29-2017, 06:09 PM   #1
balci
bullshit roads, low hanging single exhaust and coilovers
title says it all, I'm fortunate to live in speedbump/pothole central, and I am gonna put coilovers on my car, that's just a foregone conclusion either way. fuck the consequences.
now, handful of issues. my greddy revolution RS is only hanging about 3-4 inches above the ground as it is with stock ride height. no idea how much further down I can go without tearing the whole thing off at the next speedbump.
now, question is, and I've googled around and all I've gotten out of it is one guy claiming that bilstein B14 can go even higher than stock height. which coilovers out there can at the very least match, or at least come close to the stock ride height?
I've never had coilovers on a car before, and I'd rather not be stuck with a set of coilovers set that can't be adjusted higher from a, say, 20mm standard drop. Idea is basically that I can at least try and gradually lower the car from its standard ride height, and try it out from there.
and it has to be TUV certified, be glad you don't live in Norway.
EDIT: Currently looking at H&R monotube, KW V1 and the B14 as they've got TUV certification. greatly appreciate if any owners could give me a quick run down or other recommendations.
balci is offline   Reply With Quote
Old 01-29-2017, 06:12 PM   #2
Teseo
Drives: frs
Totalled
The Following User Says Thank You to Teseo For This Useful Post:
go_a_way1 (01-30-2017)
Old 01-29-2017, 06:17 PM   #3
balci
Originally Posted by Teseo View Post
Totalled
absolutely
Old 01-29-2017, 08:02 PM   #4
ryoma
ryoma's Avatar
I feel sorry for you... lol. gl
Old 01-29-2017, 08:17 PM   #5
Go the other direction.
churchx (02-01-2017), mjanmohammad (01-29-2017)
Old 01-30-2017, 06:42 PM   #6
balci
might have exegeratted a bit on the horrible roads, but they're far from nice. and our speedbumps are basically just square slabs of concrete placed at random everywhere.
anyone with any TUV certified coilovers that are able to match the original ride height?
Old 01-31-2017, 10:35 AM   #7
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Buy the coilovers you want, add 1" lift spacers from ADF, and adjust height to please.
JazzleSAURUS is offline   Reply With Quote
Old 01-31-2017, 10:50 AM   #8
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
That damn image is making Chrome warn me every time I try to load this page. Apparently bmsc.com.au got reported for phishing activity.
The Following 2 Users Say Thank You to PandaSPUR For This Useful Post:
strat61caster (01-31-2017), why? (02-01-2017)
Old 01-31-2017, 02:02 PM   #9
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
imo Bilstein will be the highest quality, I had mine setup for a half inch lower than stock (~12mm) iirc, I didn't try going higher but it's likely possible.
But this begs the question, why are you getting coilovers?
ineedyourdiddly
Cole (02-01-2017)
Old 01-31-2017, 10:06 PM   #10
Fixed. Thanks for the heads-up.
PandaSPUR (02-01-2017)
Old 02-01-2017, 07:12 AM   #11
balci
well I obviously want to lower it dont I, big question is how much.
with a coilover zeroing at stock height, I have the ability to lower it as much as I can, even if its just 15mm, or just return it back to standard.
Old 02-01-2017, 07:21 AM   #12
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
If you want to get hardcore, install some Parts Shop Max diff/Subframe risers, they will lift the diff up 40mm, then get some of their flat exhaust tubing and get an exhaust shop to modify your exhaust..
All the clearance!
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Greddy Supreme SP Exhaust & Revolution RS Single Exhaust Evasive Motorsports Groupbuys 119 01-31-2017 02:53 PM
Is this bullshit? SquadRon Off-Topic Lounge [WARNING: NO POLITICS] 101 06-16-2016 12:19 PM
WTB:TRD Exhaust, Hampton Roads Area 2FAST2FRS Want-To-Buy Requests 0 03-25-2016 09:43 PM
Exhaust hole cover for Single tip exhaust - Innovated Dynamics Kostamojen Cosmetic Modification (Interior/Exterior/Lighting) 4 06-09-2015 11:45 PM
Another project teaser. Exhaust hole covers for single exit exhaust! Wonderbar Cosmetic Modification (Interior/Exterior/Lighting) 57 05-30-2014 02:46 AM
