| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#29 | ||
Drives: '13 Ultramarine
I'm surprised no one else suggested this. Our gas tanks are a saddle type, so it would be pretty difficult to get all of the fuel out by siphoning. However, I was just outside feeling around under the car, and I think there is a drain plug on both sides of the tank. I'm doing an oil change on the weekend, so I'll have a look-see while I'm under there. Quote:
I'm fairly sure our tanks are plastic, so condensation shouldn't be an issue. I'd run the gas tank low, change the oil, put a good dose of stabilizer in the tank, go for a rip around the block, then park the car and get all the fuel I could out of it. I park the Mustang for 6 months of the year (damn winter), and leave the gas in it (with stabilizer). I haven't had any problems doing that for 7 seasons now, but 2 years gives gas a long time to turn into poo.
#30 |
Drives: '14 Whiteout FR-S
#31 |
Here's what Toyota recommends. http://www.ft86club.com/forums/attac...9&d=1379350290
#32 |
If anyone cares for an update, I returned right at the end of December.
What I ended up doing was: -disconnected and removed the battery -pumped tires slightly beyond Toyota's recommendation -filled the gas tank with gas -put in a dose of fuel stabilizer/octane booster (stuff was rated for 2 years) -put a sand bag behind each wheel. Roll onto them in neutral, then leave car in gear. Handbrake off. -stuffed a microfiber in the exhaust tip -stuffed a microfiber in the intake, behind the filter -left a note on the driver's seat to remove said microfibers I also bought a moisture absorbing thing from a dollar store and left it on the centre console. I left right at the start of January 2015. I returned for a visit in July of that year. At that time I changed the oil and took the car for a quick spin. Basically everything was fine. Couldn't tell it was ever in storage. When I left I put everything back as above. I returned for another visit in august 2016. By this time my battery was toast so I did nothing to the car. I finally returned for good at the end of December 2016. I installed a new battery and changed the oil. Car fired up with no problems. For the first 20 seconds or so it sounded and felt like the idle was a tiny bit rougher than usual, but no problems otherwise. I was impressed with how well the tires held up. I noticed a hint of shaking at highway speeds, but definitely drivable. I was able to make a 40 minute drive to my father in law's shop to get fresh michelin X Ice tires on. The car has been used daily since then with no issues. The one thing I would do differently is put the moisture absorber on a dish or something. It comes in a plastic container but it split apart. So after all the moisture was absorbed, some of it leaked onto my centre console and into the seat heater switches. Everything still works just fine, thankfully. Thanks for everyone's advice and I hope this might help someone in the future. |
| The Following 5 Users Say Thank You to FR-S Guy For This Useful Post: | Anthony (01-30-2017), Dadhawk (01-29-2017), humfrz (01-30-2017), infinitewhiskey (01-30-2017), Traffic (01-31-2017) |
#33 | |
Huge E85 fan!
Drives: 2016 Scion FRS
#34 | |
#35 |
Huge E85 fan!
It's bad for dampers to be at full extension for long periods of time. They've been known to get locked in that state and have to be replaced.
| The Following User Says Thank You to guybo For This Useful Post: | Tcoat (01-30-2017) |
#36 |
Thanks! The way you wrote it confused me and I thought you meant they would be over compressed somehow. That is why the jack stands should be under the suspension not the body of the car. Suspension components should never ever be left dangling since they are not designed for that.
#37 |
Huge E85 fan!
LOL that's a funny visual. Imagine someone putting the jack stands under the wheels
#38 |
Oh you have to know it was done at least once!
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (01-30-2017) |
| Storing for a year | dragonwiddd | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 03-05-2014 09:12 AM |
| Storing Car For 9 Months | Touge86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 16 | 11-11-2013 11:21 AM |
| Storing my car | SmsAlSuwaidi | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 06-22-2013 07:38 PM |
| Anyone storing their aftermarket parts until... | ScionFrsFan | Issues | Warranty | Recalls / TSB | 6 | 01-07-2013 08:01 PM |
| Storing an unused car? | #87 | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 02-21-2012 11:51 PM |
