Old 01-25-2017, 08:15 PM   #183
MRS-Colin
Drives: 2001 Impreza 2.5 RS
Originally Posted by modernbeat View Post
We bought one also.
That makes seven so far!
Colin Beck
MRS-Colin is offline   Reply With Quote
The Following 2 Users Say Thank You to MRS-Colin For This Useful Post:
DustinS (01-25-2017), ILLSMOQ (01-25-2017)
Old 01-26-2017, 12:12 AM   #184
all4spl
I should be buying mine this weekend.
all4spl is offline   Reply With Quote
Old 01-26-2017, 10:04 PM   #185
ILLSMOQ
Drives: 2017 WR BLUE BRZ
http://www.vorshlag.com/blog/
Vorshlag added the MRS update to their blog. Hopefully that helps kick up the pre orders too.
ILLSMOQ is offline   Reply With Quote
Old 01-26-2017, 10:08 PM   #186
Bullitt2496
Guest
Posts: n/a
FWIW my car with Weapons Grade's swap has functional push button start and AC working. Not sure how they did it though. They mentioned to me that they'll be using the MRS modules in the future too.
The Following User Says Thank You to For This Useful Post:
Sportsguy83 (01-27-2017)
Old 01-26-2017, 10:10 PM   #187
mrk1
Drives: Sterling BRZ Ltd
Do you have any plans to keep the front sway bar? aren't guys having to loose it with the LS
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-26-2017, 10:12 PM   #188
Bullitt2496
Guest
Posts: n/a
Another V8 Swap
My car front sway is installed.
Old 01-26-2017, 10:15 PM   #189
mrk1
thats good to hear
The Build Thread
Old 01-26-2017, 10:16 PM   #190
Bullitt2496
Guest
Posts: n/a
thats good to hear
The Following 3 Users Say Thank You to For This Useful Post:
DustinS (01-27-2017), M1K3 (01-27-2017), Sportsguy83 (01-27-2017)
Old 01-26-2017, 10:35 PM   #191
mrk1
sweet!
The Build Thread
Old 01-26-2017, 10:55 PM   #192
ILLSMOQ
Shorties into 3" with v-bands?...are you doing that yourself? looks great!
Still mocking it up?...doesn't look like you've finished welding yet and it looks really tight towards the rear or the transmission. May have to clearance it a bit?
Old 01-26-2017, 10:59 PM   #193
Bullitt2496
Guest
Posts: n/a
Took this pic before it was final welded. Fits great. Weapons Grade built my car and did this for me. Car has an LS3 525 with their headers and this exhaust.
Old 01-27-2017, 10:50 AM   #194
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Yeah the Vorshlag headers are why the front sway bar can't be used. Trying to decide how to move forward with the header solution. Weapons grade has said their header solution is ~$3000
I like the vorshlag headers, but really hoping to see a sway bar solution here very soon. I may wait on ordering headers until then. (Or go another direction for headers all together)
Old 01-27-2017, 10:51 AM   #195
MRS-Colin
Get some power logs and call it a day.
Colin Beck
The Following User Says Thank You to MRS-Colin For This Useful Post:
Old 01-27-2017, 11:09 AM   #196
DustinS
DustinS's Avatar
Just this picture alone show the difference between Weapons Grade and Vorshlag. Look how much further back Vorshlag got the engine.
WGP:
Vorshlag:
Does anyone see any issue with leaning the top of the radiator way forward? (Other than hose routing)
Edit: Looked at WGP Headers. They are listed at $2000. Few hundred more than Vorshlags, which is quite a bit better than the $3k I saw quoted some time ago. Just not sure on how they will fit with the Vorshlag mounts.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
