#463 | |
I haven't gotten ambitios enough to bolt a stock CB on to see if that changes anything. I do also have a bunch of bushings done, so its possible that amplifies anything thing. |
#464 | ||
Drives: 2018 Golf R
Parting out HERE
#465 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Will switching the final drive still retain cruise control and VSC functionality?
#466 |
Drives: 2018 Golf R
Yes. The speedometer maintains its OEM accuracy as well.
Parting out HERE
| The Following User Says Thank You to civicdrivr For This Useful Post: | funwheeldrive (10-12-2016) |
#467 |
Good to know, I asked because the way speed control was maintained in my G35 was due to a combination of wheel speed sensors and transmission speed sensing differentiation. A final gear change rendered it inoperable. Glad the engineers here had foresight to allow for this.
#468 |
Drives: GT86
Can anyone tell me if the Cusco 4.875 is even easy to build in as the 4.556 one?
I used to have a 4.556 one on my GT86 but would prefer the 4.875 cusco on my new BRZ. |
#469 |
I have the same issue the diff whines on deceleration sometimes. Not really loud but noticable.
2013 FR-S, AT, Braille 15lb battery, 16x7 Wedsport SA15R w 205/55/16 Continental Extreme Contact Sport, TRD drop in airfilter, TRD spring and TRD swaybars, TRD exhaust, TRD Brake Pads,4:56gear, 2740lbs
#470 |
Thanks everyone for your help on this! I installed the 4:56 set in the automatic (2013). The car really likes it, it surprisingly much more enjoyable to drive when driving normal (around town etc.) It certainly is faster with respect to acceleration. I would have probably gone with a 4:67 if I was to do it again for my Automatic Trans. This is a daily driver so that is what influenced me to choose the 4:56. If it was my second car I might consider the 4:88. We changed the fluid with a little bit of metal in there. This was after the first 1000 miles. Hopefully this gets better... Besides the whine, this mod is great. I should have gone a bit higher with a 4:67 for the Automatic Trans it would have probably been more ideal. I've changed gears in other cars before and this mod works and you can feel it. Also the gear indicator is correct with the gear change. In other words when I am in 2, 3rd, 4th etc. it actually says 2, 3. 4 next to the speedometer/tach. The speedometer is also correct! I was initially worried about this, but it is correct. : )
| The Following 4 Users Say Thank You to makesdrivingfunagain For This Useful Post: |
#471 |
Drives: frs
I dont find weir fd...
#472 |
Drives: Track preped NA FRS
#473 |
Well, I changed the diff fluid again. The first change was after 1000 miles and it had some metal. I was concerned but aware that this was part of the break in procedure and was to be expected. The second change after about 3k miles was clean : ) The diff does make a slight whine here and there and there but nothing I'm really to concerned about. The car performs noticeably better now.
#474 |
Drives: FRS
Could anyone share their track experience going to a short FD (ex. 4.56 4.88) with a supercharger (ex: JRSC)? I know the experience will differ depending on track type...slow and technical vs. fast sweeper type.
Trying to decide on FD and don't want to swap gearing depending on track. Would like to know what works and what FD would not be recommended based on your experience. |
| The Following User Says Thank You to wro77 For This Useful Post: | avishenoy1 (05-17-2017) |
#475 |
Drives: GT86 GTS
If your car is tuned will the FD throw out the tune?
#476 |
Drives: frs
| Tags |
| cusco final drive |
| PST Carbon Fiber Drive Shaft Installed | msile | Engine, Exhaust, Transmission | 155 | 08-28-2018 08:53 PM |
| Mfactory Final Drive Ring and Pinion | Crossover Auto | Engine, Exhaust, Transmission | 87 | 05-26-2017 03:21 AM |
| FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin | JM Auto Racing | Brakes, Suspension, Chassis | 271 | 03-22-2014 01:17 PM |
| Is my Cusco catch can correctly installed? | wbradley | Engine, Exhaust, Transmission | 9 | 02-24-2014 10:49 PM |
| Has anyone actually seen any of the Cusco roll bar / roll cages installed? | xenocharger | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 06-03-2013 07:54 PM |
