Old 01-12-2017, 04:36 PM   #1
allowe
allowe's Avatar
Electronic rust module
Does anyone have them installed? Where is the module located?
Reason for asking is because I've found a brochure in the papers of the car when I bought it
allowe is offline   Reply With Quote
Old 01-12-2017, 04:37 PM   #2
allowe
allowe's Avatar
Rust module location
Double post sorry. F u Tapatalk
Old 01-12-2017, 04:45 PM   #3
Will be a little box on the firewall someplace. If you paid extra for it you may as well have taken the cash and ripped it up and thrown it away.
They are a great addition to large ships that can generate enough power to work properly but a total waste of money on a car where they don't do a thing.
Old 01-12-2017, 04:52 PM   #4
Impureclient
Drives: 2015 FR-S
Never knew such a thing existed for cars. Here is a little info about how they are probably snake oil: http://www.autotrainingcentre.com/bl...st-protection/
Old 01-12-2017, 05:02 PM   #5
My son in law had them on two cars. Both rotted to the door handles in 5 years. One so bad that the shock tower let go about 5 inches away from the module. Of course they were both Mazdas but still....
Old 01-12-2017, 05:47 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
What if the polarity was incorrectly calibrated? Set to self destruct in 5years instead of 10years.
Old 01-12-2017, 05:51 PM   #7
PSi
Drives: 2017 86
you might as well go ahead and buy an "earth harness system"
PSi is offline   Reply With Quote
The Following User Says Thank You to PSi For This Useful Post:
allowe (01-12-2017)
Old 01-12-2017, 07:46 PM   #8
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
Electronic rust proof
OK guys...bring it on ...Cathodic protection is real...in any metals that contain iron...it just wants to go back home.
vintagemxer is offline   Reply With Quote
Old 01-12-2017, 08:29 PM   #9
allowe
allowe's Avatar
Ft86club forums... where talking about electronic rust modules turns into buying earth harness system and snake oil lol!
I just wanted to know where it's located so I can find out if my car came with one considering the fact that I bought it used and it had random things like the bongovi acoustics or whatever and lo jack (which I'm really happy about)
The Following User Says Thank You to allowe For This Useful Post:
Tcoat (01-12-2017)
Old 01-12-2017, 09:00 PM   #10
Well, allowe, if your car has one, as @Tcoat speculated, it most likely is attached to the firewall or at least somewhere under the hood. Since it has to be plugged in, you might look for a wire running off the positive post of the battery or a "always hot" lead out of the fuse box.
Old 01-12-2017, 09:03 PM   #11
There is no standard place to find it as they are not a standard item and get slapped on wherever the installer wanted. They are usually on the firewall near the battery.
FRSBRZGT86FAN (01-19-2017)
Old 01-12-2017, 09:03 PM   #12
....just don't let it happen again ....I have enough trouble keepen up ......
Old 01-12-2017, 09:04 PM   #13
Yes it is real and works very well in many many applications. Car modules is not one of them.
Old 01-12-2017, 09:15 PM   #14
vintagemxer
Right...I'm a (CCC) corrosion control cop on N/G pipeline...very importante !!!
Electronic Boost Controller BRZtoni Forced Induction 9 01-21-2018 02:38 PM
WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module Danklvr Audio/Visual, Electronics, Infotainment, NAV 1 09-04-2014 06:57 PM
Rust module HeadBanger CANADA 14 08-18-2014 06:54 PM
Electronic Rust Protection Fever CANADA 19 02-22-2013 12:40 PM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 05:15 PM
