Old 01-09-2017, 07:44 PM   #1
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Fuel Regulator
Throwing in a dw300 fuel pump but keeping stock injectors for my sbd400x kit. Is there any reason i would need to add a larger regulator or adjustable regulator. Cant find alot of info on this for our cars. Also how many cc are our stock injectors?
tofurun is offline   Reply With Quote
Old 01-09-2017, 08:39 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Stock injectors are 228CC. This car has a returnless fuel system, so you don't have the typical fuel regulator you traditionally change in the fuel line. The regulator here is attached to the fuel pump housing, and you do not typically change it unless going for an aftermarket return fuel system.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
tofurun (01-09-2017)
Old 01-09-2017, 09:08 PM   #3
tofurun
tofurun's Avatar
Sweeeet. Thanks man that is probably the best response I have ever received in the first reply to a thread.... Well Done sir. only 228cc? That seems crazy small to be holding these cares up to 300hp... is this because of the returnless fuel system?
The Following User Says Thank You to tofurun For This Useful Post:
Sportsguy83 (01-09-2017)
Old 01-09-2017, 09:12 PM   #4
Sportsguy83
Drives: Limited BRZ
You welcome 😀😀.
It holds this cars to 300hp comfortably because we have eight injectors. Four port injectors that are the ones at 228, and four direct injectors that are 400ish something equivalent CC. The DI's run on a separate fuel pump driven by a cam.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
Nick Dugdale (07-08-2024), tofurun (01-09-2017)
Old 01-09-2017, 09:17 PM   #5
tofurun
tofurun's Avatar
You welcome ����.
AHAH!. so my end goal one day is 350 whp. All i should need are some 700cc injectors with this dw300 pump to have the fuel system happy. or is 700cc an over kill? Also with that DI system for under 350 do i need to do anything there? new pump or rails for DI system?
Old 01-09-2017, 09:47 PM   #6
Sportsguy83
Drives: Limited BRZ
Don't worry about the DI system, there's nothing aftermarket for it.
If you plan on staying on pump gas, don't worry about the injectors. If you plan on going E85 and higher power, then upgrade injectors.
Old 01-09-2017, 09:49 PM   #7
tofurun
tofurun's Avatar
At what power point would you say do injectors?
Old 01-09-2017, 09:54 PM   #8
Sportsguy83
Drives: Limited BRZ
Stock motor is limited by knock when running pump gas to a level which you won't be able to upgrade injectors for more fuel, and that is around 350.
Now this is not end all be, some tuners have increased the pumping of the DI pump via the tune and used more injector duty cycle to support higher power, what I'm saying I'd the general rule of thumb, not set in stone.
Old 01-09-2017, 09:59 PM   #9
tofurun
tofurun's Avatar
You is a smart dude.... Thank you for your time.
Old 01-09-2017, 10:11 PM   #10
Sportsguy83
Drives: Limited BRZ
Thanks! Good luck with your build!
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 10:40 PM
Adding in line fuel pressure regulator KGZ86 Engine, Exhaust, Transmission 13 07-07-2016 06:15 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 07:21 AM
Window Regulator Bolts/Washers - TSB and new parts? PollosHermanos Issues | Warranty | Recalls / TSB 3 03-08-2014 02:17 PM
Window Regulator Mounting Bolts - Noise Issue & Part Revision? PollosHermanos Issues | Warranty | Recalls / TSB 1 03-06-2014 11:39 AM
