#253 |
Drives: 2014 BRZ brand new!
#254 |
Drives: 13 frs red
#255 |
Drives: 2013 Gt86
If youre staying NA, invest in a better Final Drive Gear. That probably be one of the best mods for the money
#256 |
Keep it simple IMHO;
TRD intake or straight line no bend CAI EL Headers with fewer bends than stock port exhaust ports to match header flange tube final drive change 4.33+ More expensive; Port the heads, TB and intake horn internal tranny gearing change Once you got everything done then get the tune instead of tuning after every single mod. Assuming you got everything done at once
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#257 |
Drives: 13 frs red
I wouldn't touch the ports or the intake.
#258 |
Drives: 2013 FR-S Argento
I haven't read this whole thread so apologies if already mentioned, but intake manifold spacers like the Crawford billet power blocks have been shown to make a nice useable shift in the power band for a street car. Those in combination with a quality long tube header, shorter FD, and a tuner who really knows what they are doing - IMHO the best and simplest approach for a street car.
| The Following User Says Thank You to bfrank1972 For This Useful Post: | why? (12-29-2016) |
#259 |
Only happy when it rains.
Drives: series.blue
#260 |
Drives: frs
#261 | |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
#262 | |
I was under the impression that the longer runners shifted the resonant characteristics of the intake so there were stronger pulses earlier in the rev band (making a slightly more use-able torque band), I'd like to know why and E85 tune changes that effect. Maybe has something to do with cam timing? |
#263 | |
#264 |
Drives: FT86
On a stock car stock tune The block shift the power band lower in the rpm range and can make a little more peak power as they shift the power band to where the engine is working more efficiently , stock.
Once you get tunes and headers then your usually chamging cam timings and also shifting where the engine is most efficient , this is often higher in the rpm range so the block work against this unless your headers and cam timings are designed to work with the blocks. Same deal with E85 it makes good power through the rpm band but does well over 5500, and the efficiency of engines with the blocks is starting to drop off past that rpm range unless you have made other specific changes to suit the blocks. So in generall the blocks work well on stock untuned cars and their effectivness drops off as you add other mods if your going to use blocks then you might be better with something like an ACE CS 400 header which is also designed for low midrange torque talk to your tuner, see what they recomend |
| The Following User Says Thank You to steve99 For This Useful Post: | why? (12-30-2016) |
#265 |
Drives: 13 frs red
I can tell you that the blocks, along with oft tune make a substantial difference in drivablilty. The dreaded torque dip is much less noticeable and there is enough grunt for a 2 litre motor.
| Recommended cheaper power gains mods | emishor86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 03-27-2016 09:49 PM |
| POWER Mods for NA setup | NYCsubaruBRZ | Engine, Exhaust, Transmission | 61 | 02-17-2016 10:19 AM |
| Mods to reduce drivetrain power loss? | FRSW12 | Engine, Exhaust, Transmission | 31 | 12-28-2015 06:10 PM |
| Easy mods for power and sound. | LWAA | BRZ First-Gen (2012+) — General Topics | 40 | 09-13-2015 10:20 PM |
| More Power VS. other Performance Mods | Darryljr11 | Mid-Atlantic | 38 | 08-11-2013 09:53 PM |
