Old 12-12-2016, 03:38 PM   #1
Legionsk88
Legionsk88's Avatar
Drives: 2015 WRB Limited BRZ
Bluetooth volume
Am I the only that seems to think the any music played via Bluetooth seems a notch or two lower in volume than the regular radio? I tend to use spotify and more times than not I find myself needing to go almost 3/4 of the max volume. Anyone else have issues with this? (ps. I found a previous post about this but no good solution)
Sent from my SAMSUNG-SM-G920A using Tapatalk
Legionsk88 is offline   Reply With Quote
Old 12-12-2016, 04:20 PM   #2
Well, I'm no audio expert, but it wouldn't surprise me that a little energy is lost in the transfer ......
Maybe the folks over in the audio section of the forum can shed some light on this question ..... ??
Old 12-12-2016, 05:01 PM   #3
swarb
1. Adjust volume on phone or use equalizer program to adjust the signal.
2. Adjust volume on head unit or use equalizer to adjust the signal.
3. SVC (sound volume control?) function on the head unit, it does not work for all the channels though.
Old 12-12-2016, 05:07 PM   #4
FX86
yeah bluetooth volume is lower..that's why i play all my music off of the usb now...higher fidelity too
Old 12-12-2016, 05:22 PM   #5
1Botnet
Drives: Scion FR-S
Same reason most non-compressed CDs have much better volume and clarity then even a direct headphone jack.
1Botnet is offline   Reply With Quote
Old 12-12-2016, 07:31 PM   #6
This is because Bluetooth (in this instance) is being used as a wireless connectivity for sound, so the initial volume is controlled by the sending device. The receiving device (the headunit) can multiply that volume but only so much.
As @swarb said, start with your phone (or whatever the device is) first, then adjust the radio. My phone, for example, won't broadcast sound above what it believes is the max volume for a headset. To go beyond that you have to acknowledge that, "yes, I know if I listen at a higher volume I will most likely go deaf".
When connecting over USB, the headunit is given more control.
yes, this is an oversimplification and there are exceptions, but this is how it works most of the time.
Old 12-12-2016, 07:39 PM   #7
stevesnj
stevesnj's Avatar
I never had an issue with Bluetooth volume on my iPhone, but I do have Sound Check and EQ set to None. Sometimes the phone volume buttons will affect volume.
My 2016 Build thread
Old 12-12-2016, 08:30 PM   #8
cjd
cjd's Avatar
Drives: 2017 BRZ
Be wary boosting beyond the normal volume control max... It can clip the output signal, and that sounds horrid even to deaf people that can't hear the horrible contribution of mp3 compression.
I actually run ~80% volume on the phone and crank the head unit to 7 or 8, though it goes a little higher on the highway what with the exhaust noise. As long as there is enough power,nothing wrong with this at all.
The Following User Says Thank You to cjd For This Useful Post:
Dadhawk (12-13-2016)
FRS/BRZ Volume level Scionguy28 Electronics | Audio | NAV | Infotainment 7 12-03-2014 08:31 AM
volume too low w\ audio from Bluetooth JoeC Electronics | Audio | NAV | Infotainment 16 10-30-2014 02:27 PM
Bluetooth Volume not Being Saved AmonReviled Electronics | Audio | NAV | Infotainment 0 07-17-2014 04:29 PM
Volume control with Bluetooth audio finch1750 Electronics | Audio | NAV | Infotainment 5 02-17-2013 05:48 AM
Fluctuating volume so26 Issues | Warranty | Recalls / TSB 9 08-16-2012 01:26 AM
