Old 12-07-2016, 05:10 PM   #1
ShootZ
Drives: 2015 Frs
Engine will not turn off!
Hey, I have a 2015 FRS, this just started happening a couple weeks ago.
When my hazards are on, I can turn the key off, all gauges, lights etc. turn off like normal but the engine stays running, even with the key out. Put the key back in, turn the hazards off and turn key off and it'll turn off.
And ideas?
ShootZ is offline   Reply With Quote
Old 12-07-2016, 05:14 PM   #2
Well that is a new one!
All stock? No mods of any kind (other than wheels or suspension)
Old 12-07-2016, 05:38 PM   #3
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Do you have a remote starter installed?
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 12-07-2016, 05:52 PM   #4
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
wait... how often do you need to turn off the car while your hazards are on?
This sounds like a real minor inconvenience, just turn your engine off first and then activate the hazards.
VIP BRZ is offline   Reply With Quote
The Following User Says Thank You to VIP BRZ For This Useful Post:
Clipdat (12-08-2016)
Old 12-07-2016, 05:56 PM   #5
Still shouldn't happen and should get to the bottom of it before it gets worse.
Patient "Doctor it really hurts when I laugh"
Doctor "well don't laugh"
c4lvinnn (12-08-2016), Clipdat (12-08-2016), go_a_way1 (12-07-2016), Stang70Fastback (12-08-2016), strat61caster (12-07-2016), Ultramaroon (12-07-2016)
Old 12-07-2016, 06:21 PM   #6
dattran86
Driver
Drives: 2013 Whiteout FRS
Could have be a bad Ignition Switch? does the same thing happen without the Hazard light being on?
dattran86 is offline   Reply With Quote
The Following User Says Thank You to dattran86 For This Useful Post:
stevesnj (12-07-2016)
Old 12-07-2016, 08:01 PM   #7
catsspat
Drives: 2013 BRZ Premium MT
Are you by any chance using one of those cheap flasher modules (for avoiding hyperflashing with LED bulbs)? If so, try putting the stock flasher back in.
Nonsense you say? When I first put LED bulbs and a cheap flasher, with everything off other than the hazards, I heard weird sound with something on the dash lighting up dimly. I'm thinking it was maybe the fuel pump. I immediately took that garbage out and picked up a Tap-turn module (Canadian).
I opened up the cheap flasher module and found 9V relays in it. Garbage. In the end, there's really no reason to use one. You can just mod the stock one to work with LEDs. See http://www.ft86club.com/forums/showp...97&postcount=8
catsspat is offline   Reply With Quote
The Following User Says Thank You to catsspat For This Useful Post:
Tcoat (12-07-2016)
Old 12-07-2016, 09:37 PM   #8
TheGuyWithTheFireStorm
Drives: FireStorm MT FRS
Anyone else wanting to see a video of this? Haha..
Sorry, this is absolutely no help
TheGuyWithTheFireStorm is offline   Reply With Quote
Old 12-07-2016, 11:53 PM   #9
You didn't answer Tcoat's (or anyone else's) question. Exactly what mods do you have, if any?
Help us help you.
Old 12-08-2016, 12:12 AM   #10
And ideas?
Hello ShootZ and welcome to our forum......
Like others have asked, what mods do you have that have something to do with the electrical system..??
Or, to put it another way, what cha been messen with ... ??
Old 12-08-2016, 12:52 AM   #11
Help us help you.
But I'm not the one with the problem...
The Following 2 Users Say Thank You to TheGuyWithTheFireStorm For This Useful Post:
Tcoat (12-08-2016), Ultramaroon (12-08-2016)
Old 12-08-2016, 01:31 AM   #12
That's no excuse.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
DatsunDimer (12-08-2016), humfrz (12-08-2016), TheGuyWithTheFireStorm (12-08-2016), treminaor (12-08-2016), ~el~jefe~ (12-08-2016)
Old 12-08-2016, 02:34 AM   #13
First off ....... "Sorry, this is absolutely no help" ....... is a problem .....
Then @Ultramaroon ask you a question ........ and you spouted off with some dribble about "But I'm not the one with the problem".
Your first step to recovery is to admit that you have a problem ......
No wonder @Tcoat gets impatient with posters ...... that have problems, then deny that they have a problem ....... and THEN don't follow advice to solve their problem.
Comments .........
Old 12-08-2016, 03:20 AM   #14
Comments .........
I think we're both getting a bit senile.
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 11:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 07:47 PM
Rattle when i turn off the engine Subforever Issues | Warranty | Recalls / TSB 11 08-18-2015 02:22 PM
