Old 11-22-2016, 11:03 PM   #169
-Willis-86touge
Drives: Stock
Oh and for some people who beleive its to high on pump numbers, remember dynos read diffent. I noticed in one pick the dynapack sign so seeing how that's there I assume it was on a dyna pack. Dyno pack it a higher reading dyno so if you do the math a good number woul be roughly 180hp sounds about right to me. The importance is how 12 volt added roughy 10 hp with the intake manifold.
-Willis-86touge is offline   Reply With Quote
Old 11-27-2016, 02:39 PM   #170
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Originally Posted by churchx View Post
What was the dyno type? I'm thinking that FD is main culprit for such drastic difference over completely stock baseline. Even if doing run in same gear, you DO have different gearing.
I agree. Many ways to "skew" the dyno numbers.
Example:
Dynapack setup requires Final Drive, Drivetrain loss, AND wheel diameter to be entered.
If you were to enter those values wrong by just a little, you would get errors in the final value.
Even running with low tire pressure in the rear would give inflated HP numbers because the effective wheel diameter would be less than the machine thinks.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
Teseo (11-27-2016)
Old 11-27-2016, 03:02 PM   #171
Teseo
Drives: frs
Example:
What about this kind of dyno? Variable of tyres is not present at least.
The Following User Says Thank You to Teseo For This Useful Post:
justatroll (11-27-2016)
Old 11-27-2016, 03:07 PM   #172
justatroll
justatroll's Avatar
I was even wondering if all dynapack dynos connect directly to the wheel hubs?
If they DO, why is there a wheel diameter setting in the setup menu?
Old 11-27-2016, 04:13 PM   #173
Maybe that part is just so the customer can get some sort of vehicle speed chart.
Old 11-27-2016, 04:38 PM   #174
Lantana frs
Drives: 13 frs red
In the middle of the summer, my car runs almost as strong as the one on the dyno.
Lantana frs is offline   Reply With Quote
Old 11-28-2016, 09:34 AM   #175
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
looking at getting an aluminum driveshaft, 6.67 final drive, and lightweight flywheel and hoping to hit mid 13s in the drag.
Dr. BRZ is offline   Reply With Quote
Old 11-28-2016, 10:19 AM   #176
Lantana frs
Drives: 13 frs red
What other mods do you have?
Old 11-28-2016, 01:01 PM   #177
CSG Mike
CSG Mike's Avatar
Yes, they do.
I wasn't aware it asked for wheel diameter...
Old 11-28-2016, 01:13 PM   #178
gramicci101
Off Topic
Yes, they do.
He probably meant tire outside diameter. That would be more important than wheel diameter for determining rolling speed.
Old 11-28-2016, 01:19 PM   #179
justatroll
justatroll's Avatar
Yes, they do.
Here
http://www.dynapackusa.com/vehicle.htm
I should have read the description.
Wheel Dia - for entering wheel diameter so equivalent ground speed can be calculated for display - not used or necessary for power and torque measurements
CSG Mike (11-28-2016)
Old 11-28-2016, 10:54 PM   #180
GenRuleAThumb
GenRuleAThumb's Avatar
Drives: 2014 FR-S
JDL UEL header
OFT E85 Tune
Top Speed axel back
GenRuleAThumb is offline   Reply With Quote
The Following User Says Thank You to GenRuleAThumb For This Useful Post:
Teseo (11-28-2016)
Old 11-29-2016, 12:20 AM   #181
justatroll
justatroll's Avatar
Originally Posted by GenRuleAThumb View Post
JDL UEL header
OFT E85 Tune
Top Speed axel back
Sorry but our cars have ~12-13% drivetrain loss (MT).
Your peak wheel HP shows up as 174.6
174.6 * 1.13 = 197.3 HP
So your engine is outputting right about 200 hp
What am I missing?
(Hint: 'drag power' is way too high @ 41 hp).
41 hp of drivetrain loss on a engine hp of 216 is 19% loss
See what I mean about "tweaking dyno settings" to show power where it isnt?
And thats without being able to see any of the Rotating mass numbers.
The Following 2 Users Say Thank You to justatroll For This Useful Post:
gtengr (11-29-2016), why? (12-01-2016)
Old 11-29-2016, 12:41 AM   #182
gramicci101
Off Topic
What am I missing?
Ok, you're an engineer, so hopefully you can explain this to me. Why is drivetrain loss expressed as a percentage instead of a static number?
Say your car makes 200 bhp, and for ease of math it loses 20 hp (10%) through drivetrain loss. You do some mods to it and now it's making 300 bhp. You're still spinning the same gears at the same speed in the same fluid, so it should still only lose 20 hp, not 30 hp (10%), right? If expressing it as a percentage is correct, why would drivetrain loss go up just because power went up, when the workload to spin all the gears and whatnot hasn't changed?
Recommended cheaper power gains mods emishor86 Scion FR-S / Toyota 86 GT86 General Forum 38 03-27-2016 08:49 PM
POWER Mods for NA setup NYCsubaruBRZ Engine, Exhaust, Transmission 61 02-17-2016 09:19 AM
Mods to reduce drivetrain power loss? FRSW12 Engine, Exhaust, Transmission 31 12-28-2015 05:10 PM
Easy mods for power and sound. LWAA BRZ First-Gen (2012+) — General Topics 40 09-13-2015 09:20 PM
More Power VS. other Performance Mods Darryljr11 Mid-Atlantic 38 08-11-2013 08:53 PM
