Old 11-21-2016, 04:34 PM   #1
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Stripped strut rod, need suggestions
I was torquing my ST Coilovers rear to nut to 41 lb ft to fix some clunking noises. One side did it fine, other stripped. KW customer support said it should be 15 ft lbs but I doubt that will help my noises because I fixed front clunk by going beyond their 25 ft lbs front spec. Before resorting to warranty repair which will cost a few hundred, I'm going to get a tool to re-thread it.
Anyone have success re-threading a strut rod before? Anyone happen to know the thread pattern and size for the ST kit? Top nut is 17mm.
Old 11-21-2016, 04:40 PM   #2
You would have to go to a smaller size you can't just rethread to the 17mm. I would be afraid of it failing when stressed. Not something I personally would mess with to be honest.
Why would it be a warranty repair if you went past their spec? It wasn't defective so will they cover it?
Old 11-21-2016, 04:43 PM   #3
switchlanez
They sent me the form to cover it. I've been emailing them these past few weeks about the noises so maybe they're being lenient on those grounds.
Sent from my Pixel using Tapatalk
The Following User Says Thank You to switchlanez For This Useful Post:
Tcoat (11-21-2016)
Old 11-21-2016, 04:59 PM   #4
Icecreamtruk
Drives: Track preped NA FRS
Then do the warranty repair before they change their minds?
Icecreamtruk is offline   Reply With Quote
Old 11-21-2016, 05:22 PM   #5
jasonojordan
Drives: 2013 satin white brz limited
Im with tcoat id just sent it in not mess around with it. Not likely you will be able to safely repair it. How long did you drive it with the clunk?
jasonojordan is offline   Reply With Quote
Old 11-21-2016, 05:33 PM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Odds of success: uncertain, possible, maybe even probable
Odds of them denying a repair after you fuck with it: high
Cost of just buying another damper, what, $150?
ineedyourdiddly
Old 11-21-2016, 07:20 PM   #7
switchlanez
KW clarified it is not a warranty repair so they would charge me $135 to rebuild it plus whatever work to take off the stripped nut (I will try to DIY that off) plus shipping both directions.
Old 11-21-2016, 07:22 PM   #8
switchlanez
Buying a complete replacement damper is $459 and it has a revised wet valve insert and male hex rod (opposed to dry insert and female Allen in mine which they discontinued).
Old 11-21-2016, 07:25 PM   #9
strat61caster
Well, thanks for the info at least, hope you find a good solution.
ineedyourdiddly
Oil filter threading stripped davtbaum Issues | Warranty | Recalls / TSB 53 06-03-2017 02:10 PM
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 02:50 PM
Good platform for stripped down gt3 car? WGMGR Scion FR-S / Toyota 86 GT86 General Forum 16 07-14-2015 02:19 PM
Wheel bolt stripped 2pointSLOW86 Issues | Warranty | Recalls / TSB 23 10-13-2014 03:29 AM
Have you stripped some weight off your FRS? gt8613 Scion FR-S / Toyota 86 GT86 General Forum 39 08-20-2013 03:11 PM
