#155 | |
Drives: Toyota GT86
We can mod, but there are so many restrictions if wanting to keep it legal. Just as an example I can't get the wheels I want (Enkei RPF1), because they don't have TÜV approval. I have a limited choice of coil-overs etc etc. Brakepads? Forget being legal!.. As we say here when someone asks for advice: "Do you want to be legal, or do you want to be able to brake?".
#156 | |
Drives: '14 981CS, '99 NB1
| The Following User Says Thank You to johan For This Useful Post: | Ultramaroon (11-10-2016) |
#157 |
Make the twins great again.
| The Following 9 Users Say Thank You to Ultramaroon For This Useful Post: | AKBrrrrrrrrZ (11-10-2016), chaoskaze (11-20-2016), CSG Mike (11-10-2016), drew_kar (11-11-2016), gramicci101 (11-11-2016), Lynxis (11-11-2016), meWant (11-11-2016), sato (11-12-2016), why? (11-12-2016) |
#158 |
This is how you baseline 17 OEM suspension vs.... JRZ, Ohlins DFV, and Tein SRC.
#159 | |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
Edit: Lucky SOBs, I am stuck in the office all day. Although i may close early since half my customers took off for veterans day.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#160 | |
Grr. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | brzaapi (11-14-2016) |
#161 |
So, I can confirm that a 13-16 intake fits on a 17 MT engine (red manifold). The only issue is that the clip that holds the MAF harness against the intake is in the wrong orientation.
MAF scaling needs to be for 17, not 13. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#162 |
CAR-AHOLIC
I know you havent likely had this on the track yet, but i was curious after a couple more weeks if you could share anymore experience on the '17 MY willingness to rotate?
Mid-Corner Dynamics? Rotation? Does the car suck back in when you lift? or continue on the line like the Zenki models? I may be early on these questions, but I am just damn curious.
#163 |
![]() Hmmm... why are BOTH of my cars here? |
#164 | |
Lifting can cause terminal understeer or oversteer, depending on the loading of the suspension when you lift... in most cases it'll understeer. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | brzaapi (11-21-2016) |
#165 |
Off Topic
| The Following User Says Thank You to gramicci101 For This Useful Post: | funwheeldrive (11-17-2016) |
#166 |
This is happening
#167 |
Drives: 2014 Firestorm Scion FR-S
Just saw this thread and want to take a crack at it, for fun. Specifically:
CSG-spec Brembo GT Tein SRC 3-way CSG built heads TWS wheels On a more general level I want to guess this build is leaning more towards the N/A route based on (what I interpret as) hints toward raising the redline, and the fact that it's a "big surprise" as opposed to what's already out there (lots of boosted track builds). |
| The Following User Says Thank You to lbejosano For This Useful Post: | CSG Mike (11-19-2016) |
#168 |
Not bad! 8 sessions between two tracks, and plenty of laps.
Wear is pretty even with the evaluation set of dampers and a last minute eyeballed at the track alignment. Tire temps had less than 12F total delta across each tire AND all 4 tires.
| Mad Mike's Firestorm Build | Mad_Mike | Member's Car Journals | 90 | 01-21-2026 09:08 PM |
| My thoughts on my build (Down South in Africa)! | 86 South Africa | Member's Car Journals | 2 | 02-02-2016 07:55 AM |
| Mike&Ikes WRB Build | Mike&Ike | Member's Car Journals | 8 | 09-18-2015 03:12 AM |
| Mike Mac's Raven FR-S NYC Build | ScionFR-S | Member's Car Journals | 5 | 06-07-2014 01:49 PM |
| Mike's CS FR-S build | mikef | Member's Car Journals | 6 | 04-25-2013 09:11 AM |
