Old 10-27-2016, 08:22 PM   #99
Tor
Tor's Avatar
Drives: Toyota GT86
How is the new "track" mode?
Tor is offline   Reply With Quote
Old 11-02-2016, 08:34 AM   #100
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Hows the "oil cooler line" problem going?
Cause you have to get this car to a track, on the track...going around the track.
Going FAST!!!
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 11-02-2016, 01:40 PM   #101
johan
Drives: '14 981CS, '99 NB1
Easy fix for oil cooler line problem:
swap to the 13-16 airbox.
The 17 autos still have the 13-16 airbox... so there's no reason it wouldn't be a direct swap. Boom, there's the space you need.
johan is offline   Reply With Quote
Old 11-02-2016, 02:01 PM   #102
JDM4E
Drives: Honda Accord Euro
Additionally, the older HIDs output a much broader spectrum of light, versus the LEDs, which put out a lot of blue, but very little yellow or green. As a result, green/white highway signs are almost black/white at night, and yellow center lines are a very pale highlighter yellow instead of a very rich orange/cheese yellow.
This sux. I wonder, if there is/will be any LEDs replacements with better CRI. Low CRI is a "problem" across the whole LED industry and LEDs with a good Color Rendering Index is relatively rare and expensive.
JDM4E is offline   Reply With Quote
Old 11-02-2016, 02:03 PM   #103
ajc209
Drives: GT86 Cosworth
Auto also has the old unmodified engine.
ajc209 is offline   Reply With Quote
Old 11-02-2016, 02:33 PM   #104
johan
Of course, but the differences in the airbox are minor - and we already know the 13-16 airbox can flow enough air to make 250-300hp on a supercharger with a different filter.
I just wanted to offer this as an idea for a simple / cheap way to get rid of the problem.
The Following User Says Thank You to johan For This Useful Post:
funwheeldrive (11-02-2016)
Old 11-02-2016, 05:36 PM   #105
CSG David
CSG David's Avatar
Going FAST!!!
Still working on a proper solution.
A good idea, but doesn't necessarily mean it's the proper solution. Something designed correctly is far more beneficial to the community.
Soon.
Yea...AT sucks, except for DD life with boost. That is very fun.
Old 11-02-2016, 06:09 PM   #106
johan
Absolutely - won't disagree with you there. It just opens up your options from an individual owner perspective. If you're in a rush to get a cooler on a '17. It'd be the fastest way to get access to the large existing market of oil cooler solutions for the chassis.
Old 11-02-2016, 07:56 PM   #107
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Do the K&N (or similar) drop-in air filters work for the 17MT? Or will it require new filter dimensions?
Drambeenie is offline   Reply With Quote
Old 11-02-2016, 09:11 PM   #108
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I think you should but a Ferrari engine in there.
http://www.ferrari-tractors.com/
Old 11-02-2016, 10:09 PM   #109
johan
I don't know. Subaru did change the dimensions / design of the filter for '17 MT, but I don't know if it was in a way that changes compatibility.
Old 11-02-2016, 11:12 PM   #110
CSG Mike
CSG Mike's Avatar
Different dimensions
Old 11-02-2016, 11:13 PM   #111
CSG Mike
CSG Mike's Avatar
Or I could put on an aftermarket intake.
Unfortunately that means more money, and the new stock intake works rather well.
I've never taken the easy way out before, and am not about to start now.
johan (11-02-2016)
Old 11-02-2016, 11:30 PM   #112
Drambeenie
Drambeenie's Avatar
Hmm...Doesn't sound like it's gonna work. I was hoping to bring the filter to the dealer when I pick up the car. Hopefully they release a compatible one before the end of december.
Mad Mike's Firestorm Build Mad_Mike Member's Car Journals 90 01-21-2026 10:08 PM
My thoughts on my build (Down South in Africa)! 86 South Africa Member's Car Journals 2 02-02-2016 08:55 AM
Mike&Ikes WRB Build Mike&Ike Member's Car Journals 8 09-18-2015 04:12 AM
Mike Mac's Raven FR-S NYC Build ScionFR-S Member's Car Journals 5 06-07-2014 02:49 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 10:11 AM
