Old 11-01-2016, 06:17 PM   #1
BrunoCr7
Drives: 2017 Subaru BRZ
Turning off manual brz with push to start
Do I have to hold in the clutch when turning off my car?
BrunoCr7 is offline   Reply With Quote
Old 11-01-2016, 06:27 PM   #2
funwheeldrive
Nope, only when starting the car. I always try to make sure the car is in neutral with the ebrake on before pushing the button to turn the car off.
Old 11-01-2016, 06:41 PM   #3
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Then put it in either reverse (downhill) or 1st gear (uphill) afterwards.
krayzie is offline   Reply With Quote
The Following 6 Users Say Thank You to krayzie For This Useful Post:
Bowen (11-01-2016), Drambeenie (11-01-2016), funwheeldrive (11-01-2016), M-17 (11-04-2016), pinski (11-02-2016), Watch Me Run (11-02-2016)
Old 11-01-2016, 08:19 PM   #4
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Does shutting it off in gear hurt? Not that I've ever done it. Just curious.
Sent from my Pixel using Tapatalk
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 11-01-2016, 08:44 PM   #5
krayzie
Drive From Home
krayzie's Avatar
What if you get leg cramps before you manage to hit the button?
Old 11-01-2016, 11:24 PM   #6
ryoma
ryoma's Avatar
I shut off my car in gear in the pit and avoid ebrake but that's the only time I do it. I don't know if it's good for the car though. just make sure you double check your stick position before turning on the car.
Old 11-02-2016, 12:21 AM   #7
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
my car wont allow you to coast. I haven't determined the minimum speed...yet
thomasmryan is offline   Reply With Quote
Old 11-02-2016, 12:26 AM   #8
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
You can turn the car off whenever you want, with the pedals in whatever positions you want. The only way it will hurt your car is if you turn it off while rolling, because then the steering could lock if the car isn't in "run mode" and you could crash into a house before you can stop.
Stang70Fastback is offline   Reply With Quote
Old 11-02-2016, 08:02 AM   #9
extrashaky
Drives: 2014 BRZ Limited
No. Try it and see.
No, unless you're rolling.
Stick position shouldn't matter until you actually start to move the car, since you can't start the car without pushing the clutch.
6 mph in first gear at 1000-1100 rpm on flat ground. Below that, you'll lug the engine. You have to use a light foot to hold that speed.
The car knows when it's in motion, and I would be really surprised if the steering will lock while rolling. What if you had an engine failure? That would be a recipe for news coverage and lawsuits.
Old 11-02-2016, 03:52 PM   #10
Stang70Fastback
A.K.A. Starlord
If you have an engine failure, the key is still in the run position, and the vehicle continues to operate in that mode, as best as it can. It's an entirely different situation if you turn the key back to 'ACC' or 'OFF'. THAT is what could cause the steering to lock.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Ganthrithor (11-05-2016)
Old 11-02-2016, 04:17 PM   #11
fizzymike
fizzymike's Avatar
Drives: 2014 Silver BRZ
No if your stopped and have the clutch in its fine.
fizzymike is offline   Reply With Quote
Old 11-02-2016, 06:41 PM   #12
extrashaky
If you have an engine failure, the key is still in the run position...
No it isn't. It's in my pocket. Per the thread title, we're talking about push button start.
Old 11-02-2016, 07:23 PM   #13
Stang70Fastback
A.K.A. Starlord
It still operates under the same principles. If the engine stalls, the car stays in "run." If you turn the key, or press the button, then you are forcing the car out of run mode.
I also looked at the Owner's Manual. It looks like the steering lock function won't engage until you open a door. So that's one less thing you need to worry about. You'd still lose power brakes and power steering but at least the car is driveable.
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
ajaxthebetter (11-04-2016), Ganthrithor (11-05-2016)
Old 11-03-2016, 12:30 PM   #14
about94ninjas
Drives: 2015 WRB BRZ Limited 6AT
This is not true, I have done it many times. While driving, if you pop the car into neutral, and push the button 3 times, the engine will shut off, but you still have full control over the steering, without the power assist of course. In fact, the steering wheel will not lock even after parked until you open the door. If you turn the car off with the door closed, and then open the door, you can hear the wheel locking.
about94ninjas is offline   Reply With Quote
Push start cdrazic93 Cosmetic Modification (Interior/Exterior/Lighting) 6 08-18-2014 10:34 PM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
GTS come with push start? adam AUSTRALIA 13 06-04-2012 04:28 AM
