#15 | |
Drives: Toyota GT86
My slave cylinder seems fine and fluid level is where it's supposed to be. Regardless, I'm installing a new clutch and putting in the stock flywheel back eventually along with a velox clutch fork and pivot. For the meantime, it will do just fine as long as it "works". Sent from my Nexus 6P using Tapatalk |
#16 |
Drives: 13 Subaru BRZ, 02 Audi TTQ
It may not work for long, when I had an ACT clutch about 1000 miles after the inconsistent engagement point and shuddering when taking off started the car would no longer go into gear.
#17 | |
Drives: Toyota GT86
#18 |
The fork was flexing so the throw out bearing wasn't engaging strait. When I took it apart the tob was damaged and I saw that at one corner of the pressure plate the springs weren't released all the way.
| Clutch height adjustment | Hugo | AUSTRALIA | 13 | 04-30-2020 01:12 PM |
| Clutch Adjustment Issues!! | FT-86- | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 05-28-2015 09:29 PM |
| Clutch Pedal Adjustment? | EAGLE5 | Northern California | 41 | 05-20-2015 01:10 AM |
| Easy Clutch Grab Adjustment | frsfreak | Southern California | 2 | 03-28-2014 04:13 AM |
| Clutch Adjustment Concern | ZackZ | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 09-07-2013 05:01 PM |
