Old 10-19-2016, 06:34 AM   #15
BRX
BRX's Avatar
Drives: Toyota GT86
Originally Posted by simpleisbest View Post
Sounds like your clutch fork could be already bent. If it is your slave, then simply pop the hood, squeeze the slave cylinder boot to see if there is any collection or hydraulic fluid and check your clutch fluid reservoir to see if you lost any fluid. Considering you needed to adjust the pedal so much to just get the clutch to disengage though, sounds like a bent fork.
I actually read on another thread that someone else had to adjust his pedal after installing the same clutch as mine. It's not that it wouldn't disengage it was just very close to not being able to. Also I had installed injectors at the same time so the tune was off at idle.
My slave cylinder seems fine and fluid level is where it's supposed to be. Regardless, I'm installing a new clutch and putting in the stock flywheel back eventually along with a velox clutch fork and pivot. For the meantime, it will do just fine as long as it "works".
Sent from my Nexus 6P using Tapatalk
BRX is offline   Reply With Quote
Old 10-19-2016, 04:08 PM   #16
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
It may not work for long, when I had an ACT clutch about 1000 miles after the inconsistent engagement point and shuddering when taking off started the car would no longer go into gear.
Scenic Driver is offline   Reply With Quote
Old 10-19-2016, 05:33 PM   #17
BRX
BRX's Avatar
Drives: Toyota GT86
What was the cause of the problem? Bent clutch fork?
Old 10-20-2016, 03:42 PM   #18
Scenic Driver
The fork was flexing so the throw out bearing wasn't engaging strait. When I took it apart the tob was damaged and I saw that at one corner of the pressure plate the springs weren't released all the way.
Clutch height adjustment Hugo AUSTRALIA 13 04-30-2020 02:12 PM
Clutch Adjustment Issues!! FT-86- Scion FR-S / Toyota 86 GT86 General Forum 39 05-28-2015 10:29 PM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 02:10 AM
Easy Clutch Grab Adjustment frsfreak Southern California 2 03-28-2014 05:13 AM
Clutch Adjustment Concern ZackZ Scion FR-S / Toyota 86 GT86 General Forum 19 09-07-2013 06:01 PM
