#57 | |
Yep. When you are talking a space as crowed as the engine bay of these cars a 1/2 inch can be the difference between fitting or not a hope in hell.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | CSG Mike (10-17-2016), DarkSunrise (10-17-2016) |
#58 | |
Sorry, but pass. I don't want to be checking the banjo bolts every session. Absolutely correct; the more "square" rear makes it so 2 lines cannot fit side by side back there... |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#59 |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
My mind didnt even go to the fittings (mind you this was pre-caffeine), but that makes perfect sense. Well aftermarket loves to create intakes, so i am sure this will be addressed here shortly. Easier to fix the air box, than to re-route or relocate oil lines or components.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#60 | |
Now, if for some reason the car is restricted to the OEM airbox... |
#61 |
This is happening.
Gotta make sure things stay looking fresh. https://www.instagram.com/p/BLq8ASdjgdy/
| The Following User Says Thank You to CSG Mike For This Useful Post: | gramicci101 (10-17-2016) |
#62 |
Off Topic
That's the one thing I regret not doing as soon as I got my car.
| The Following User Says Thank You to gramicci101 For This Useful Post: | stock (12-17-2016) |
#63 |
Drives: GT86 Cosworth
FWIW I am using the mishimoto banjo fittings but with a mocal oil to water laminova. They started to seep oil a little bit after I initially installed them.
I tightened them up but I added anti tamper paint so it would be obvious if they start coming lose. Its usually vibration that causes them to come lose, so need to make sure there is some play in the oil hose. Just my 2 cents. I was very nervous using them and was checking under the bonnet every time I used the car for a while. Its now done 3 trackdays and about 5k road miles. If I get them come loose again they will go in the bin and I'll live with 10min track sessions until I can figure out a better solution. |
| The Following 2 Users Say Thank You to ajc209 For This Useful Post: | DarkSunrise (10-18-2016), dj2020 (10-18-2016) |
#64 | |
Short shifting will work, if your primary goal is car control rather than chasing lap times... |
#65 | |
Stock I would hit 140C within a 20minute session on cooler days. |
#66 | |
Yeah, the extra torque helps, especially when you don't need to rev as much! |
#67 |
Time Traveller
If the clearance is right and if the quality is up to par, and if you can source the sandwich plate from the SARD oil cooler kit, it might do the trick. @nigel-jdmparts might still have a lead. Still looks tight to me.
http://www.more-japan.com/blogs/2013...rs-subaru-brz/ ![]()
| The Following User Says Thank You to DAEMANO For This Useful Post: | ajc209 (10-18-2016) |
#68 | |
#70 |
| Mad Mike's Firestorm Build | Mad_Mike | Member's Car Journals | 83 | 03-14-2025 01:16 AM |
| My thoughts on my build (Down South in Africa)! | 86 South Africa | Member's Car Journals | 2 | 02-02-2016 08:55 AM |
| Mike&Ikes WRB Build | Mike&Ike | Member's Car Journals | 8 | 09-18-2015 04:12 AM |
| Mike Mac's Raven FR-S NYC Build | ScionFR-S | Member's Car Journals | 5 | 06-07-2014 02:49 PM |
| Mike's CS FR-S build | mikef | Member's Car Journals | 6 | 04-25-2013 10:11 AM |
