Old 10-13-2016, 12:38 AM   #29
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Originally Posted by nickson555 View Post
The iDatalink Maestro module outputs are controlled by the firmware to fit with the harness you install. The HRN-RR-TO1 for FRS.
When I changed the firmware, the first time it kinda faked it and it didn't really change. (I tried to change it before the first install) If you really change the model of the car on the web site in your profile, it will ask again for the Serial number of the new head unit.
With the FRS set in your idatalink profile, you will now see more features and it tell it requires the HRN-RR-TO1 harness to work with.:
I just used the RR and cut into harness like it said. didnt even know i had an option for this wireharness set up.... w/e gauges still work lol
tofurun is offline   Reply With Quote
Old 10-13-2016, 12:40 AM   #30
tofurun
tofurun's Avatar
For Future readers. Some Ecu Tec race rom versions will not send the OIL PIDs through OBD2. This means that idatalink and things like torque will not read your oil temp after your tune. I have been advised from @DeliciousTuning this is an ECUtec issue. I will eventually try to contact ecutec directly. Doubt i will get anywhere lol.
Old 10-18-2016, 02:01 PM   #31
nickson555
Drives: 2015 Subaru BRZ Limited
The oil temp reading is like the most important thing on this car.
nickson555 is offline   Reply With Quote
iDatalink with kenwood stero in FRS? sero901 Electronics | Audio | NAV | Infotainment 4 07-04-2016 11:07 PM
iDatalink 2015 model anyone? Mikeez Electronics | Audio | NAV | Infotainment 1 09-03-2014 11:38 PM
Dummy Antenna? FnFast Cosmetic Modification (Interior/Exterior/Lighting) 3 05-01-2013 09:07 AM
Dummy door lights housing Razor Scion FR-S / Toyota 86 GT86 General Forum 5 10-11-2012 07:59 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
