Old 09-16-2012, 11:08 PM   #1
Razor
Razor's Avatar
Drives: FR-S in Raven 6MT
Dummy door lights housing
Does anybody knows how to activate the door lights? It would be nice to have the extra light when getting In or Out.
Razor is offline
Old 09-16-2012, 11:16 PM   #2
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
For the FR-S, they're just red reflectors... If you want lights; you need to wire them in and add a bulb.
Only the Toyota version and Subaru Limited has the courtesy lights from factory...
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline
Old 10-11-2012, 06:45 PM   #3
FuzionTeknique
FuzionTeknique's Avatar
Drives: FRS-Asphault
Check this out.. Courtesy lights for FRS.. we rewired them, install was not bad.. the lights are worth it! They are bright white LED with a light red flash...
FuzionTeknique is offline
Old 10-11-2012, 06:50 PM   #4
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
I'm sure the harness is in the door and a BRZ one will fit. Does anyone have a picture of the BRZ lighting?
20valvewynn83 is offline
Old 10-11-2012, 06:56 PM   #5
FuzionTeknique
there is no harness or any wiring in the doors of the FRS.. I would be curious to see what the inside of the BRZ light looks like. here is a pic of the type of harness that is on these LED courtesy lights.. For the FRs i have to remove it and add more wire to run one to the ground under the ignition and one to the fuse box for the power.
Old 10-11-2012, 06:59 PM   #6
FuzionTeknique
here is the pic...*
DIY: Black Housing Tail Lights sw20kosh DIY (Do-It-Yourself) Guides 151 11-21-2016 04:08 PM
Black Housing Tail Lights (FR-S) sw20kosh Cosmetic Modification (Interior/Exterior/Lighting) 20 04-13-2016 11:38 PM
Door sill lights? jazztennor Cosmetic Modification (Interior/Exterior/Lighting) 7 11-15-2012 03:49 PM
Door lights question Eric_86 Scion FR-S / Toyota 86 GT86 General Forum 9 08-27-2012 11:41 PM
