Old 10-12-2016, 04:25 PM   #29
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
This may have happened.
Just temporary, but I was curious. It's a one-off Titanium catback engineering sample for what could have been a CSG Titanium catback exhaust.
It's good for about 21 lbs of weight reduction from a stock catback, without compromising aero. It's insanely loud without cats, but for now, it's okay.
Now, you do understand Mike....that if you install that exhaust....well, there goes your warranty.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following 5 Users Say Thank You to brzaapi For This Useful Post:
FirstWinter (10-21-2016), funwheeldrive (10-14-2016), gramicci101 (10-12-2016), meWant (10-12-2016), PollosHermanos (10-15-2016)
Old 10-12-2016, 05:42 PM   #30
CSG Mike
CSG Mike's Avatar
Originally Posted by brzaapi View Post
A quick question about the '17 Mike. With the suspension revisions, mainly the use of a thicker rear sway bar, do you still believe that on a stock BRZ/FRS that an aftermarket sway will still be beneficial for the cars rotation.
I know you were an advocate for a thicker rear sway on stock '13 - '16 models to help us track guys dial out the understeer and get a little more rotation in the turns.
I know this may take some time to sort out while you are breaking the car in......but share when you can.
I won't know until I baseline a stock 17 BRZ. I have a rather tight timeline, so I may or may not be able to do that with my car, but I know the opportunity will come along sooner or later.
Old 10-12-2016, 05:43 PM   #31
CSG Mike
CSG Mike's Avatar
This will be great to watch. Have you ever owned an BRZ/86 in the past Mike, or is this your first one?
First BRZ/86/FRS for me, although I think I've racked up over 100k miles between various shops' cars, private coaching clients, setup consultations, and friends' cars.
Old 10-12-2016, 05:46 PM   #32
CSG Mike
CSG Mike's Avatar
Originally Posted by spicyricecake View Post
Looks similar to the MXP SP one I picked up from CSG recently
Originally Posted by JazzleSAURUS View Post
Looks like the MXP SP I got from CSG...
Very excited to see how this goes. Something something ACE, something something AP sprint....
One of those "could still be produced" exhausts... if there is demand...
This is less than half the weight of the MXP SP. It's all Titanium.
Old 10-12-2016, 05:54 PM   #33
AirWick
Drives: 2016 Halo Scion FR-S
Let me see if I have $2000 lying around somewhere...
Join our Orange County 86 Meets!
Check out my Youtube Channel!
AirWick is offline   Reply With Quote
The Following User Says Thank You to AirWick For This Useful Post:
CSG Mike (10-13-2016)
Old 10-12-2016, 06:56 PM   #34
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Lemme guess...
Tein something or other, unless you spring for Penskes
AP sprint BBK
JRSC - custom EcuTek tune
Lots of cooling
Some aero
17x9 wheels - forged, so not rpf1
upgraded radiator and big-ass oil cooler
hood venting
maybe a clutch
pmu pads, of course
How far am I off?
Old 10-12-2016, 08:42 PM   #35
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
Originally Posted by jsimon7777 View Post
Lemme guess...
AP sprint BBK
Lots of cooling
Some aero
hood venting
maybe a clutch
pmu pads, of course
How far am I off?
Boy are you guys in for a big surprise...
SuperDave is offline   Reply With Quote
Old 10-12-2016, 09:55 PM   #36
gramicci101
Off Topic
Low boost turbo
Clutch type LSD
Anderson Fab 2" lift
Rock sliders
Skid plates
16" Sparco Terras
BFG All-Terrains
http://www.ft86club.com/forums/showthread.php?t=105692
The Following User Says Thank You to gramicci101 For This Useful Post:
EAGLE5 (10-13-2016)
Old 10-13-2016, 01:36 AM   #37
EAGLE5
Dismember
EAGLE5's Avatar
Those are just the things Mike seems to sell or recommend the most. As a dual purpose car, the stock suspension is great. As a track weapon, you need to do a lot of work, especially when adding HP.
Old 10-13-2016, 11:11 PM   #38
CSG Mike
CSG Mike's Avatar
Lemme guess...
AP sprint BBK
Lots of cooling
Some aero
hood venting
maybe a clutch
pmu pads, of course
How far am I off?
Actually, almost completely
DustinS (10-14-2016), EAGLE5 (10-14-2016)
Old 10-13-2016, 11:12 PM   #39
CSG Mike
CSG Mike's Avatar
I haven't done anything on a closed circuit yet, but I've gotten the tires making noise without VSC kicking in yet.
While the damping isn't critical from the factory (it's designed more for comfort), the balance seems to be much closer to neutral than before.
I probably should have hopped on the skidpad before I left work today.
Tcoat (10-14-2016)
Old 10-14-2016, 08:10 AM   #40
brzaapi
CAR-AHOLIC
brzaapi's Avatar
This just shows, that we are all good listeners....to what you have to say Mike.
However, you havent steered me wrong yet. In fact i can think of two times when i went against your advice, only to have to back track after problems arose...and then proceeding the way you originally had mentioned.
So i have learned, that you have learned from your 100k plus (Track?)miles on the 86 platform.
Daily: Audi TT RS
Last edited by brzaapi; 10-14-2016 at 08:11 AM. Reason: Post - proof read - then edit
The Following 2 Users Say Thank You to brzaapi For This Useful Post:
CSG Mike (10-14-2016), Tcoat (10-14-2016)
Old 10-14-2016, 08:55 AM   #41
The fact that even after all those miles and time spent working on the cars Mike still went with one as his personal vehicle says more to me than all the promotional hype ever written by Subaru/Toyota!
The Following 10 Users Say Thank You to Tcoat For This Useful Post:
brzaapi (10-14-2016), CSG Mike (10-14-2016), funwheeldrive (10-14-2016), Lynxis (10-17-2016), meWant (10-14-2016), Mim (10-14-2016), mrg666 (10-14-2016), Rampage (10-17-2016), Ro_Ja (10-30-2016), why? (10-14-2016)
Old 10-14-2016, 10:20 AM   #42
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I had this thought myself, but it is very true and needed to be said.
Mike, I am curious though...were there any other cars you were considering?
Besides a 3rd S2000
Daily: Audi TT RS
The Following User Says Thank You to brzaapi For This Useful Post:
Mad Mike's Firestorm Build Mad_Mike Member's Car Journals 90 01-21-2026 10:08 PM
My thoughts on my build (Down South in Africa)! 86 South Africa Member's Car Journals 2 02-02-2016 08:55 AM
Mike&Ikes WRB Build Mike&Ike Member's Car Journals 8 09-18-2015 04:12 AM
Mike Mac's Raven FR-S NYC Build ScionFR-S Member's Car Journals 5 06-07-2014 02:49 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 10:11 AM
