Old 09-29-2016, 07:43 PM   #15
renfield90
The Stig's German cousin
MT, never spend any time at 4k rpm.
The only reason to do that is to make noise.
...or you're going faster than 90.
Old 09-29-2016, 07:46 PM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
If I'm doing over 90 I'm in 4th gear over 5k rpm thankyouverymuch.
But I suppose those that live in flyover states with 90 mph speed limits probably do hang out at that rpm.
ineedyourdiddly
Old 09-29-2016, 07:48 PM   #17
LS1M
Drives: 2015 BRZ
The only problem is if you're cruising at 2.5K rpm, and you accelerate, then lugging the engine will cause knock and that's bad. Your automatic transmission will automatically downshift if you need to pass someone. Us MT guys have to do that ourselves.
There ain't no power below 3K so I save that for long steady stretches, to save gas.
-Mark
LS1M is offline   Reply With Quote
Old 09-29-2016, 08:07 PM   #18
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
No.
Let's rephrase the question to:
Is it advisable/advantageous to cruise at 4k rpm instead 3k rpm for normal street driving, or on the highway/freeway?
shiumai is offline   Reply With Quote
Old 09-29-2016, 08:42 PM   #19
My short answer is NO ......
One of the few times that I "cruised" at over 4,000 RPMs, in a low torque, low HP car, was at 14,000 feet in a loaded down miata.
Why? Because just in case I needed every bit of power that puppy had to pull (push) me through a curve ....... especially on what were the gravel sections.
Do you see the guardrails to save you ...... ?? You don't, because there weren't any.
Yep, your machine will be happier cruising at 3,000 rather than 4,000 rpms .....and you will save gas ........
shiumai (09-29-2016)
Old 09-29-2016, 10:05 PM   #20
shiumai
shiumai's Avatar
Originally Posted by Icecreamtruk View Post
Pull it thru that torque valley baby!
My car is supercharged -> no torque valley
OP - just because you can, doesn't mean you should. Don't focus on a number or specific RPM (except redline); just pick the gear that provides what you need at that time. Choose your gear by feel and engine sound. If you need more acceleration, downshift. If you need to save gas, stick to 2500 to 3000 rpm. There's no need to buzz up and down streets or the freeway at a constantly higher rpm unless you just want to make noise, run at a higher oil temp or waste fuel unnecessarily. With the AT (which I have as well), I shift manually or keep it in sport mode , which keeps the revs about 500 rpm higher than normal mode. normal mode tends to bog the engine in stop and go traffic, and is more suited to freeway cruising.
Like @humfrz illustrated, there are times when you would drive at higher revs, like in the canyons or on the track, when you want to keep in a certain power band. But not typically needed for every day normal driving.
The Following 4 Users Say Thank You to shiumai For This Useful Post:
humfrz (09-29-2016), MuseChaser (09-30-2016), soulreapersteve (09-30-2016), Tcoat (09-29-2016)
Old 09-29-2016, 10:42 PM   #21
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Listen to your engine, it'll tell you where it wants to be for an RPM range.
If you are going at a steady speed for a long stretch, keep your RPMs under 3000 to save some gas. As for the autobox, it'll automatically keep to a safe and fuel conscious RPM range. If you want to cruise at 4k RPM 1) you should have gotten a MT 2) Watch your transmission temps and make sure it's in a happy range. 3) (Q for for those with a slushbox) Does Torque Pro have tranny temps and what is a happy tranny temp for this car?
guybo is offline   Reply With Quote
Old 09-30-2016, 12:30 AM   #22
Yal
#subaruambassador
Yal's Avatar
Drives: Wheezy
I've got the AT and the only time that I'm up around 4k is in the mountain portion of my commute. I don't worry about overheating the headlight fluid as I ponied up for the optional headlight fluid cooler.
Yal is offline   Reply With Quote
Old 09-30-2016, 11:56 AM   #23
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
I can't think of a single good reason why you'd want to drive around "cruising" with your engine at 4000 rpm. If you were climbing an incredibly steep hill with a car loaded w/ cinderblocks and that was the only way to keep the car up to the speed you wanted, then OK. Otherwise... why?!?
Think of riding your bicycle. Would you want to pedal furiously w/ very little resistance in the pedals to go a certain speed, or at a comfortable 60-70 rpm cadence (what most casual bicyclists use, including myself) w/ a bit of resistance felt to work against? On a bicycle, you choose the gear that gets the job done most efficiently and with the least amount of effort/wear from/on the rider (the engine) in a given scenario. Cruising around at 4000 rpm is like riding a bike on a flat smooth road in the lowest gear, requiring you to pedal like mad. Even worse, unlike on a bike, when you take your foot OFF the gas in your car, the engine will create a lot MORE resistance and slow the car down faster than it would in a higher gear. Going down a steep hill, that's desirable.. OK, that may be an another instance where "cruising" at 4000 rpm might be a good idea; going down a steep hill and using engine braking instead of overheating your brakes.
Otherwise, I'm stymied by the original question. Why would you want to? The upper ranges are for acceleration and power. I routinely cruise flat roads between 2000 and 2500 rpm, and downshift when I need more power.
Still confused by the desire to stay in the upper ranges....
Barry
MuseChaser is offline   Reply With Quote
The Following User Says Thank You to MuseChaser For This Useful Post:
Cole (09-30-2016)
Old 09-30-2016, 11:58 AM   #24
c4lvinnn
Drives: Toyobaruion
Barry
Um, because cruising sometimes means (Texas highways for me specifically) going 80+ and 80 is right at 4000 RPMs? Nothing you can really do about it except change the final drive ratio and I don't care that much.
c4lvinnn is offline   Reply With Quote
Old 09-30-2016, 12:20 PM   #25
shiumai
shiumai's Avatar
That's a specific situation where you don't have the choice to upshift any more as you're mechanically limited. Then of course, it makes sense to do so.
I wish socal cruising speeds were 80+ (without drawing attention).
Old 09-30-2016, 12:24 PM   #26
c4lvinnn
Drives: Toyobaruion
Just making a point to say cruising at 4k RPMs isn't going to kill your car or anything like that. And sometimes that cruising at 4k RPMs is just that, you're cruising at 4k RPMs, lol. Just seems like a lot of replies here are like "WHY?!!?!" um because that's the gear ratios they put in the car and I'm going at a normal rate of speed?
The Following User Says Thank You to c4lvinnn For This Useful Post:
shiumai (09-30-2016)
Old 09-30-2016, 12:26 PM   #27
wparsons
wparsons's Avatar
I drive around the city with rpm's really low, cruising at high rpm is just making noise and wasting gas. You can easily drive around town in 5th (MT) at 60km/h+ without lugging the engine, just don't floor it and expect it to accelerate.
flickr
Old 09-30-2016, 12:59 PM   #28
strat61caster
This engine doesn't lug until you're well under 2k rpm, makes no power below ~2.5k, sure, but it's not lugging.
Or you're putting in shittier gas than California gets...
About 80% of Socal has cruising speeds of 80 mph, you just live in the 20% where cruising speed is 20 mph
ineedyourdiddly
Transmission swap: auto to manual... itdansharpe Engine, Exhaust, Transmission 39 02-12-2018 05:53 PM
Transmission Manual and Auto For Sale 2k miles sokol Transmission and Driveline 19 01-27-2016 04:49 AM
Keep Auto Transmission or Switch to Manual Stayreal Engine, Exhaust, Transmission 41 03-23-2014 11:02 AM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 12:33 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
