Old 09-27-2016, 12:00 AM   #1
VABeachBRZ
30k Maintenance
I'm at about 28k miles and I'm looking to do my maintenance soon. I have a list, but I'm posting it here to see if it's a good route:
I'm running a c38 SC kit with Flex Fuel, DW Injectors, DW Fuel Pump and a UEL.
Here's the list and please tell me bad or good:
-Motor oil:Amsoil 5w-20 (Dom Racing oil) or 5w-30
-Trans: GL-4
-Diff: 75w-90 GL-5
-Amsoil Oil Filter
VABeachBRZ is offline   Reply With Quote
Old 09-27-2016, 12:53 AM   #2
radroach
Drives: car
I had a brake fluid flush at 30k.
The Following User Says Thank You to radroach For This Useful Post:
strat61caster (09-27-2016)
Old 09-27-2016, 12:54 AM   #3
-Trans: GL-4
-Diff: 75w-90 GL-5
-Amsoil Oil Filter
Looks OK, except the owners manual recommends GL-3 for the transmission ...... but, it's your call ......
Also, you might want to change the clutch/brake fluid.
Old 09-27-2016, 01:14 AM   #4
gramicci101
Off Topic
The transmission fluid shoots out sideways, so plan for that.
Old 09-27-2016, 01:59 AM   #5
Well now ....... ya lost me .....??
Old 09-27-2016, 10:39 AM   #6
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I don't remember it being particularly dramatic...
JazzleSAURUS is offline   Reply With Quote
Old 09-27-2016, 01:32 PM   #7
kch
Senior Misanthrope
kch's Avatar
I got trans fluid on my face the first time because I didn't expect it to shoot so far. That stuff smells terrible.
Old 09-27-2016, 01:36 PM   #8
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Ah, the 'ol mechanic facial.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 10 Users Say Thank You to 8RZ For This Useful Post:
ajcarson11 (09-27-2016), Crashdummy (10-13-2016), e_lunatic (08-04-2017), Kwaziekeller (09-27-2016), menikmati (09-27-2016), MrBlaze-65 (09-27-2016), MrFisty (09-27-2016), Nah (11-06-2016), Tokay444 (11-06-2016), VABeachBRZ (09-27-2016)
Old 09-27-2016, 04:20 PM   #9
VABeachBRZ
I've never done a break flush, but yes I need to do it. I'm sure it's just as easy as changing oils.
Any brand you suggest?
Old 09-27-2016, 04:40 PM   #10
MrBlaze-65
Drives: 2014 Subaru BRZ
I'll be doing the same soon enough, got the stock filter and washer though.
MrBlaze-65 is offline   Reply With Quote
Old 09-27-2016, 06:12 PM   #11
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I've never done a brake flush, but yes I need to do it. I'm sure it's just as easy as changing oils.
$/value, using street/hybrid brake pads: ATE Typ 200
ineedyourdiddly
DarkSunrise (09-27-2016)
Old 09-27-2016, 09:58 PM   #12
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
I'll be honest with you -- There are terrible things that i'd rather do than be hit in the face with used transmission/gear oil. The smell is absolutely HORRID. It does come out of the transmission from the side, and will come out with a reasonable amount of force at first. You definitely want a pan to catch it... You'll see what I mean by 'horrid' soon.
I also need to do a brake fluid flush -- So i'm interested to hear responses as well.
ajcarson11 is offline   Reply With Quote
Old 09-28-2016, 01:49 AM   #13
ryoma
ryoma's Avatar
did you taste it?
Old 10-12-2016, 11:40 PM   #14
Mattstermh
Drives: '13 FR-S A/T - Stock
Just did my 60k maintenance at the local Toyota dealer I normally go to. They charged me $930... I'm never going there again.
$330 for parts and $660 for labor. They were kind enough to give me a slight discount.
Here is what I had done:
Plugs
Oil, air and engine filter (Mobil 1)
Diff fluid, AT fluid, brake flush
I'm honestly shocked. On the phone she tells me a total of $3xx and then I see this labor charge. Outta control
Mattstermh is offline   Reply With Quote
First Car & First Maintenance. JARE_ee Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 04-14-2016 11:23 PM
50k maintenance RickyRacer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-27-2015 01:21 AM
For those who do their own maintenance FR-S89 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-24-2014 12:03 PM
25,000 Where can I go for maintenance. laley81 Southern California 9 09-20-2013 05:00 AM
