Old 09-23-2016, 10:02 PM   #1
AndyNguyen
Drives: Silver Scion FR-S
Wheel Spacer Help.
So I have Enkei T6S 17x8 +45 on my car and they already have a hubcentric ring on them. I am wanting to get bolt on wheel spacers (20mm) so they can have a little more flush look. My question is that since the wheels have a hubcenteric ring already, do I or do I not need to get hubcentric wheel spacers or not.
AndyNguyen is offline   Reply With Quote
Old 09-27-2016, 01:32 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Want Flush? I'd put 245/40/17 tires on them and call it a day.
Having said that, Fewer parts to perfectly line up is better.
Good luck!
Old 09-27-2016, 03:35 PM   #3
8R6
8R6's Avatar
Drives: FRS
the hubcentric ring is just to help the wheel be mounted dead center easily. if you get hubcentric spacers, you'll just re-use the hubcentric ring since the spacer's hub will be the same as the stock hub. if you get spacers that have a larger hub, then the hubcentric ring you have right now wont even fit on the wheel/spacer combo.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Leonardo (09-27-2016)
Wheel Spacer Size?? tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 11-03-2018 04:36 AM
Wheel Spacer Lug Nut Replacement? Wyattkb Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-12-2016 04:06 AM
3mm wheel spacer vroom4 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-16-2014 01:36 AM
Wheel Spacer tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-06-2013 02:44 AM
