Old 09-21-2016, 08:30 AM   #1
haavardnk
Drives: GT86 2013
How long are stock wheel studs?
Anyone know how long the stock front wheel studs stick out from the wheel hub?
Going to order some spacers, and since my wheels dont have holes in the back they need to be at least as thick as the length of the stud to not go against the rim..
haavardnk is offline   Reply With Quote
Old 09-22-2016, 01:34 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
http://www.ft86club.com/forums/showthread.php?t=21563 replacement DIY
Stock wheel studs can accept a 3mm slip spacer safely. Some guys run up to a 5mm slip spacer. You will need longer/aftermarket studs to go with a bigger spacer.
Old 09-22-2016, 02:19 PM   #3
Icecreamtruk
Drives: Track preped NA FRS
Im sorry but you didnt understand his question at all...
To OP, I dont have the exact measurements but with a 25mm spacer (the ones that bolt unto the hub) I can use my wheels that dont have space in the back either. So 25mm at the very least.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Leonardo (09-22-2016)
Old 09-22-2016, 02:54 PM   #4
kch
Senior Misanthrope
kch's Avatar
The series.blue wheels had that issue with bolt-on spacers. I believe you'll need a 20mm, but I'm not 100% sure.
Old 09-22-2016, 03:04 PM   #5
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
OP - if i were you I'd take the 10 mins to jack the car up, pull the front wheel and measure the studs to be sure.
shiumai is offline   Reply With Quote
Old 09-22-2016, 05:29 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
via Imgflip Meme Generator
Icecreamtruk (09-22-2016)
Old 09-27-2016, 05:07 AM   #7
dito
Drives: SWP BRZ
25mm for sure. the nut sits flush when tourque down on stock studs and fits wheels with no back pad holes.
dito is offline   Reply With Quote
Old 09-27-2016, 04:39 PM   #8
8R6
8R6's Avatar
Drives: FRS
yeap you'll need at least 25mm spacers to clear the stock studs
8R6 is offline   Reply With Quote
Old 08-05-2021, 08:20 AM   #9
Jarvbrz
Drives: Subaru BRZ
Hey guys I'm having a similar problem as well, I went with the project kics 11mm bolt on spacers but with the set of wheels I got they don't have an indentation for the stock studs to stay in, I was thinking of getting a 10mm slip on spacer but I wasn't sure what length to get for extended studs without having to worry about the wheel not sitting flush to the hub. I appreciate any help I could get, Thank you!
Jarvbrz is offline   Reply With Quote
Subaru field engineer says OEM wheel studs only good for 75 to 80 wheel changes Pat Tracking / Autocross / HPDE / Drifting 86 07-16-2021 11:50 AM
ARP Wheel Studs FR-S Matt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-09-2015 07:50 PM
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 09:31 AM
WTB OEM Wheel Studs Anthony Want-To-Buy Requests 8 08-27-2014 04:22 PM
Spacers and stock wheel studs solidONE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-31-2013 09:55 AM
