Old 05-20-2016, 12:05 AM   #15
steve99
Drives: FT86
Mate check out this thread
http://www.ft86club.com/forums/showthread.php?t=104695
this guy is pretty smart and good with diagnostics etc , its just a hard fault
put it to stock and let the dealer do it under warantee, save yourself a lot of hassle, worth it even if you have to pay to get it fkashed to stock
Old 05-20-2016, 12:10 AM   #16
Ashikabi
Ashikabi's Avatar
Already shot down for warranty service
Old 05-20-2016, 12:13 AM   #17
steve99
Drives: FT86
what about back to stock and try different dealer ?
Old 05-20-2016, 12:14 AM   #18
Ashikabi
Ashikabi's Avatar
I suppose that could work. How does Toyota not keep track of this stuff?
Old 05-20-2016, 12:17 AM   #19
steve99
Drives: FT86
note sure mate, privacy laws might stop it
Old 05-20-2016, 12:30 AM   #20
Ashikabi
Ashikabi's Avatar
I'll give it a shot if this doesn't work. I'll keep you guys posted, thanks for the replies
Old 09-22-2016, 09:38 AM   #21
TatharPallan
Drives: 2015 Subaru Blue Series - Pearl
Did you ever get your car fixed?
Dealer has worked on my car a few times to fix the p000b code. I had the same issue. full NA bolt-ons with tune. I reverted back to stock with base tune and the code came back on.. they have currently had my car for a week trying to fix. :-P
2015 BRZ Series.Blue CWP (K1X) - JDL UEL Header, 3" JDL Res FP, 3" JDL OP, 3" Perrin Res Cat back, 3" Perrin BigMAF Intake/Inlet tube, Perrin Light Weight Pulleys (AC, Water Pump, Crank) - Moto-East FFK - E85 Tuned by HRI - ECUTEK - Eibach Pro-Kit Lowering Springs
TatharPallan is offline   Reply With Quote
Old 09-22-2016, 10:00 AM   #22
Ashikabi
Ashikabi's Avatar
Double post
Old 09-22-2016, 10:09 AM   #23
Ashikabi
Ashikabi's Avatar
Yes but you're not gonna like it... dealers story was that I spun a bearing which contaminated the oil which plugged the cam control valves, which locked in a "low oil pressure" alarm in to the ecu. Fix: new short block, all cam sprockets/actuators and control valves replaced, new ecu. I'm not sure if the bearing spun first or a valve went bad and starved a bearing. Total time for repair 5 weeks with a regional technician being called in from Kansas city for 2 weeks.
The Following User Says Thank You to Ashikabi For This Useful Post:
Tcoat (09-22-2016)
Old 09-22-2016, 12:42 PM   #24
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
For reference, I had a thread going about cam timing. Same issues, but I had no CEL.
I went ahead with replacement of all 4 cam actuators. Turns out, 3 of the 4 were broken, but not "enough" to throw a cell.
Likely, either your cam sprocket spring has broken and/or an internal lock/pin is broken.
Is yours a 2013? This issue seems to happen most commonly in the 2013. Subaru/Toyota released a revised part number in 2014.
SpectreRT is offline   Reply With Quote
Old 09-22-2016, 01:25 PM   #25
They're saying somehow magically the metal particles made it past your oil filter yet were big enough to jam your VVT mechanism?
Old 09-22-2016, 01:53 PM   #26
Ashikabi
Ashikabi's Avatar
The only way I could see it working that way is if the oil traveled past the crank to the cam actuators, then the filter. It was covered under warranty so it doesn't matter to me I suppose.
Mine was a 2013
Old 09-22-2016, 02:12 PM   #27
Mine was a 2013
Yeah, but it doesn't work that way. Fresh oil washes through the journals and drips straight to the pan. Glad it was warrantied but it was chickenshit of them to feed you a line like that.
Old 09-22-2016, 02:16 PM   #28
Ashikabi
Ashikabi's Avatar
Once I heard a bad cam valve would starve the crank I pretty well figured that was what happened and they were idiots/liars. It did take them 5 weeks to fix it after all...
Technical information on the Toyota D-4S system arghx7 Engine, Exhaust, Transmission 72 01-13-2025 09:43 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 11:19 PM
Wiring code information for BRZ/FR-S one2onejackpot DIY (Do-It-Yourself) Guides 2 02-16-2016 04:10 PM
p000d CEL+Innovate supercharger MattF Forced Induction 13 08-16-2013 01:22 AM
Help! Looking for Toyota "loss payee" information CaptainSlow Other Vehicles & General Automotive Discussions 1 03-26-2013 11:31 AM
