-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   Code P000d Toyota information (https://www.ft86club.com/forums/showthread.php?t=105839)
Ashikabi 05-16-2016 01:00 PM
My FRS threw the P000d code with a couple P0024 so it's going in to the Toyota dealer to get fixed, hopefully under warranty. I know Subaru has a TSB out for this problem but I doubt the guys at the Toyota dealer will care. So does anyone know the TSB number for Toyota? I want to be able to cite the TSB to help avoid warranty issues.
Ashikabi 05-18-2016 09:20 AM
Update. That's has no TSB for this and if you are tuned, they will not warranty. Low battery voltage may have caused this problem, I'll be sure in the next couple days
steve99 05-18-2016 08:35 PM
their is subaru tsb its known problem http://www.ft86club.com/forums/attac...0&d=1352490977
did you tell them you had tune ? or are you turbo ?
even then they should still warantee a known issue like cam actuators as its difficult to see how even a turbo would contribute to the problem unless its melted wiring or something. but they will likely give you a hard time
Ashikabi 05-18-2016 08:49 PM
There is a Subaru tsb but no Toyota one so they don't care. No turbo but since the cam timing is changed that's what caused the problem. Also they are physically incapable of working on the car, even outside warranty, unless it's stock...
ZionsWrath 05-18-2016 08:50 PM
No they are saying they don't want to work on your car.
Plenty of dealers work on modified cars.
Ashikabi 05-18-2016 08:55 PM
Yup. I've already moved on. It's looking like low voltage may have been the cause all along
steve99 05-18-2016 09:00 PM
if its just header and tune, put beck stock header flash stock tune and send it in
its highly unlikely they will work out it has a tune unless you tell them or its plainly obvious due turbo\sc.
plenty of dealers work on modded cars, they could refuse if mods physicaly interfere with them gaining access or charge you extra for the extra time it takes though.
They could probably refuse on safety grounds if their uncomfortable with stuff like electric supercharger high capacity batteries and wiring etc.
Ashikabi 05-18-2016 09:33 PM
I'm on headers and e85. If I have more problems I'll go to the Subaru dealer
Ashikabi 05-19-2016 12:55 PM
Update! Code is back, battery didn't fix it. I now have codes for both banks: p0014, p0024 p000b, p000d. The local Subaru dealer is willing to throw parts at it but claim their diagnostic equipment won't give them reliable information because of the tune.
Last time I changed my oil I put 5w30 in(amsoil gave me the wrong stuff and I didn't realize till it was too late). Could the decrease in viscosity cause "blocked" oil passages? Anyone else have a fix here? Looks like the early adopters of the FRS had these same issues. Some got new cam sprockets, some new sprockets and ECUs. New actuators are 200$ each control valves are 75$. Should I replace a valve and see if that fixes it, then move up to actuator? Labor looks intensive for the actuator
steve99 05-19-2016 11:55 PM
that oil weight will be fine as long as it was quality full synthetic SN rated. been running that or 10w30 for last 3 years
Techstream will connect fine even if car tuned.
yes tune will alter the cam timing from stock, but what their looking for is a difference between what the ecu commands and what the cam actuator does or the sensor thinks the actuator has done.
if it was me i would be bending over backwards to keep them happy, even if that ment flashing back stock tune. That cam issue is difficukt to fix and isolate and can be a combination of expensive assemblies like actuators cam sprokets sensors oil control valves and possibly even the ecu itself. These bits can be worth thousands help them out as much as you can
steve99 05-20-2016 12:00 AM
that oil viscosity wont be a problem
Ultramaroon 05-20-2016 12:01 AM
+1 to what Steve said. Your 5w30 didn't do it. Neither did your tune but put it back to stock anyhow.
Ultramaroon 05-20-2016 12:02 AM
Yeah, +1 to this too.
Ashikabi 05-20-2016 12:03 AM
If oil doesn't fix it then I'm going to replace the oil regulator valves cuz that's easy and next on the list. Then I'll go back to stock do they can work on it. Oil viscosity "shouldn't"be the cause but I gotta rule it out
