Old 06-23-2012, 09:07 PM   #1
was385
Drives: MT WRB BRZ Limited, 2007 911s
Muddled sound issue
Had my BRZ for about two weeks and started noticing a couple of days ago that every once in a while the sound would get really clear and then become muddled and switch back and forth a little. I'm about to take it in to the dealership to have them look at it but I just wanted to know if anyone else has had the problem?
was385 is offline   Reply With Quote
Old 06-23-2012, 09:10 PM   #2
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Is this when listening to the radio or another source. I noticed something like this with the radio and finally realized it was happening when it would switch between the HD and standard versions of the same station.
Old 06-24-2012, 12:21 AM   #3
Razz
Razz's Avatar
Drives: Fast
check the settings
make sure its at FRS not TC
Also, check auto sound control
Razz is offline   Reply With Quote
Old 06-24-2012, 12:23 AM   #4
was385
I didn't notice it before, but now that you mention it, the problem only happens when it's on the radio.
Old 06-24-2012, 10:06 AM   #5
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
Yeah, mine does that as well. Although when it switches to regular radio, I think that it never sounds this bad in every other car!
Lil Abner is offline   Reply With Quote
Old 06-24-2012, 12:23 PM   #6
Razz
Razz's Avatar
Drives: Fast
The question is... What is causing the switching?
Please check your settings and report back here.
Old 06-24-2012, 12:29 PM   #7
Lil Abner
The switching is caused by a lack of HD radio signal. When the system receives a low HD signal, it switches to standard radio. I prevents dropped audio.
Ever watch digital TV? When it looses pieces of the signal, you'll see squares in the picture and/or the audio sounds like it's broken-up.
Basically, the system is doing it's best to NOT loose signal. It's a nice feature compared to sounding like a broken record.
How to avoid it? Turn off HD radio and listen to regular radio.
Old 06-28-2012, 01:14 AM   #8
Carlsbad
Drives: 2013 Subaru BRZ WRB Limited MT
I do have the same issue. It is more pronounced on FM channels, but it is also on satellite radio.
I have noticed that the twitters started to have noise also.
Overall the radio connection is fairly poor. When I pass under any overpass the connection gets interrupted.
Equally navigation reception is poor also. It does loose satellite connection and when it does connect it is the wrong location.
The resolution of the navigation is also poor. I can sit at the intersection at it tells me I have 100 ft to the intersection. Roll 10 feet and then it goes to 50 and 0. If you listen to the command you can easily miss the turn.
This poor resolution translates to poor address hunting. It often tells me I have arrived when I have another 100 ft to go.
I am collecting all these defects so when I take it in they can address them all.
Blown twitters
Poor radio connection
poor satellite connection
poor navigation resolution
Overall boomy sound does not matter how I adjust it
My $150 alpine stereo in my other car with only two boston acoustic speakers has a much superior sound
My $100 Garmin navigation has better resolution and has never dropped out or got confused about where we are
I hope I have a defective system
Carlsbad is offline   Reply With Quote
BRZ Headlights Issue? billysangi BRZ First-Gen (2012+) — General Topics 32 01-09-2017 07:06 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 11:42 AM
Starting issue Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 33 08-15-2013 08:40 AM
iPod issue? Mr.Jay Electronics | Audio | NAV | Infotainment 12 02-10-2013 03:41 AM
First 86 issue and advice Mr.Eightsix Scion FR-S / Toyota 86 GT86 General Forum 34 05-19-2012 12:49 PM
