go_a_way1
Old 09-20-2016, 12:01 AM   #3235
86Speedy
Drives: 2013 scion frs
how will this fit
17x9+ 30 245/40/17 on swift springs / stock suspension? thx
86Speedy is offline   Reply With Quote
Old 09-20-2016, 12:27 AM   #3236
swarb
Originally Posted by 86Speedy View Post
17x9+ 30 225/40/17 on swift springs / stock suspension? thx
Fits if that tire size even exists.
Old 09-20-2016, 01:55 AM   #3237
86Speedy
my bad 245/40/17 sorry
Old 09-25-2016, 07:49 PM   #3238
HachiRo
Drives: 2013 White-Out FRS
Yes it will.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 09-26-2016, 09:04 AM   #3239
Morphus1
Drives: GT 86
Looking at going RB V1.
I want the CR2P's 19"
11 back
10 front
Max camber negative 3
I've been told a variety of offsets and need some help...
Anyone know what my offsets should be for a flush finish
Morphus1 is offline   Reply With Quote
Old 10-03-2016, 02:38 PM   #3240
Leonardo
Country Boy 4 Life
Leonardo's Avatar
11 back
10 front
I'm going to do this a little different... Let me ask you a a few questions... Are you still looking at going RB V1? Have you installed it? Can you take measurements with your suspension components that allow -3 camber? Have you talked to the wheel manufacture to see what they offer?
AWESOME!!!!
Old 10-07-2016, 10:02 PM   #3241
Ricks919
Drives: 2014 BRZ brand new!
currently have 17x9 +35 with 245/40/17. cusco coilovers (pillowball mount) lowered all the way in he front and only 1/2 inch taller than that in the rear. im looking fo all season tires, found some i like, but im wondering if a 255 width tire will fit without rubbing? anyone with a similar setup that can confirm? ive turned the wheel lock to lock and looked at clearance and it looks prettttty tight. idk. little wider tires couldnt hurt as long as they fit. thanks!
Ricks919 is offline   Reply With Quote
Old 10-08-2016, 04:11 AM   #3242
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Will 18x9.5 +45 with 265/35R18 rub the rear bumper tab? Tires will be Hankook Ventus V12 which run narrower than most. Lowered 1.4" with -2.5 camber.
Old 10-27-2016, 04:08 PM   #3243
ztrevs
ztrevs's Avatar
Drives: 17' CWP BRZ ------- 15' GLA45 AMG
Specs:
18x9.5 +38
245/40/18 Bridgestone RE71Rs.
Car is bone stock, will not be lowering until early summer 2017.
Question 1: Will it fit stock suspension? No rubs at full lock?
Question 2: Will it fit after 1 inch drop come summer time? (Eibach Pro Kits)
ztrevs is offline   Reply With Quote
Old 10-28-2016, 07:19 PM   #3244
CatalystPLUR
That Auto Guy
CatalystPLUR's Avatar
Drives: Ultramarine FRS
17x8 +35 on coils.
Would 235/45/17 or 235/40/17 be better??
CatalystPLUR is offline   Reply With Quote
Old 10-28-2016, 09:46 PM   #3245
Hyperblu
Hyperblu's Avatar
Drives: 2016 Series.Hyperblue BRZ
17x9 +35 with a set of 245's. Will it fit with a 1 inch drop or do I need other things for good fitment. Only suspension pieces I have are H&R Super sport springs
Sent from my SAMSUNG-SM-G930A using Tapatalk
Hyperblu is offline   Reply With Quote
Old 10-29-2016, 12:57 AM   #3246
swarb
I'm on 255/35 on 18x9.5 +35 -2.7 camber and my bumper tabs don't exist anymore. I'm probably lowered about 2 inches.
Compared to your setup, you gain 10mm from the offset but lose 5mm(10mm/2) from the tire. I'd say you will rub.
Originally Posted by ztrevs View Post
Specs:
18x9.5 +38
1. Not all cars are the same, but you will have about 3-8mm of clearance to the strut or less. A 3-5mm spacer would help.
2. When you drop it, the car will gain camber. That would reduce the clearance. You won't really know until you try it, but it will be less than the 3-8mm mentioned above. I personally wouldn't risk damaging the wheels or getting into a sticky situation. 9.5's don't fit good on stock struts, they either poke or rub or are dangerously close. A 3-5mm spacer would help.
245/40's are for 17's. 40 series is for 225 or 235 on 18's.
245/35 is a much better choice. On 18's you will be a full inch taller than stock.
Originally Posted by CatalystPLUR View Post
17x8 +35 on coils.
Look up the tire you plan to buy and compare it to the stock tire, which is 24.6 diameter(24.7 in other brands). 235/40 is closer to stock, but slightly smaller. 235/45 is a tad tall, but do'able, it's a wrx size. I like a 25inch tire, I'd personally go 245/40(grip) or 225/45(comfort) and lastly 235/40 for a tiny acceleration gain. Depending on the tire and your goals...
245/40 will fit. Chance you might need a 3-5mm spacer up front due to camber and not all cars are made the same, we are talking a few mm here, maybe about 10mm clearance? Depending on how much clearance you are willing to accept.
The Following User Says Thank You to swarb For This Useful Post:
Leonardo (10-29-2016)
Old 10-29-2016, 04:30 AM   #3247
15limited
15limited's Avatar
You should have plenty of room, closest point of contact would be your tire to the spring perch. I'm slightly lower in the front with -1.5 camber and I wouldn't want to get any closer than that, same wheel specs and tire width. I've heard tire manufacture measurements can vary but I've ran Falkens and... whatever different tire I'm on now and neither rubbed. I would recommend camber bolts anyways and an alignment to get this dialed in to where you want them.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 10-29-2016, 02:06 PM   #3248
Hyperblu
Hyperblu's Avatar
So they dont have the wheels I want, but they have similar size but with a +45 offset, im not too good with offsets so Im not really sure if they fit?. Im reading up on it but if theres any threads out there with info I could use I'd really appreciate a link. Thanks!
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
