Old 09-16-2016, 03:50 PM   #1
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Am I level? Where do I check, you ask?
I know this may be painfully obvious for some and some of you may just think close enough is good enough, but not everyone shares that sentiment, so be nice.
OK. So I'm about to change my AT fluid and the procedure is pretty specific about some details, i.e. exactly how much fluid to put in, how much to drain out, exactly what temperature the AT fluid is to be at, making sure the vehicle is level.... and from what I understand, if it's not just right, it won't shift correctly and I only want to do this once!
Now since I have to do this using 2 different sets of jack stands and on a garage floor that is already NOT level (and most garages are not, mine was a full 2 inches lower where the rear tires sit as compared to the front tires), I got to thinking, where is the best spot to place my 2 foot level to make sure my car is indeed level, once I'm up in the air.
So I drove my rear wheels up onto 2 inches of wood then found a nice, easy spot to check, turns out, right on the door threshold is just about perfect.
As far as side to side, the intake manifold makes for a nice place to lay your level. (as you can see, mine is off just slightly right to left but my floor is off that same amount)
Floor left to right (for comparison sake)
BirdTRD is offline   Reply With Quote
Old 09-16-2016, 04:08 PM   #2
Brayden_23
Drives: Asphalt 2015 FRS
You might be overthinking this. As long as you are generally on flat ground, this should be a non-issue. Your car needs to be on flat ground so when you fill up the transmission, the fluid will seep out when full. If you are on a pronounced hill, you may overfill or underfill (depending on orientation). However, on a very minor slant such as your 2 inch difference in your garage, I don't think you will encounter any issues.
Somebody correct me if I'm wrong.
Brayden_23 is offline   Reply With Quote
The Following User Says Thank You to Brayden_23 For This Useful Post:
Norville Rogers (09-16-2016)
Old 09-16-2016, 04:16 PM   #3
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
I second this notion
Toyarzee is offline   Reply With Quote
Old 09-16-2016, 04:25 PM   #4
BirdTRD
Simply Forgotus
BirdTRD's Avatar
I completely understand and maybe that 2 inch difference doesn't matter, but once the car was up on jack stands, who knows if maybe I got it even lower in the rear, now it's 3 inches out. Where do you draw the line?
I was just looking for a good place to slap a level on, just to make sure I had a good point of reference. Might as well know where 0 is.
Old 09-16-2016, 04:33 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
Wow!! I just love this forum! Always learning something new to consider and worry about!
The Following User Says Thank You to JD001 For This Useful Post:
Old 09-16-2016, 04:46 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by Norville Rogers View Post
my bullshit allergy flares up something rotten at times...
Well, I was going to suggest a posh lazer level as spirit levels are prone to deviation due to air pressure and whether the reading is taken at sea level.
new2subaru (09-16-2016)
Old 09-16-2016, 04:48 PM   #7
Nothing wrong with peace of mind. I suggest referencing the flange for the pan. Not the bottom because that's set at an angle.
**edit: Or I could take a crack at the service manual where I would discover that the car should be level. I agree with the door threshold reference.**
Try a google image search for "tx6a transmission."
BirdTRD (09-16-2016), soulreapersteve (09-17-2016), Toyarzee (09-16-2016)
Old 09-16-2016, 04:52 PM   #8
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Thanks for being Level headed!
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
Toyarzee (09-16-2016), Ultramaroon (09-16-2016)
Old 09-16-2016, 04:53 PM   #9
Oooooo... *cough cough*
Old 09-16-2016, 04:55 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
I'm now bricking it as I've just googled and the world isn't flat.
In Subaru land things come in 4's and flat! But not level according to bottom flange on the pan.
Old 09-16-2016, 05:10 PM   #11
DarkSunrise
DarkSunrise's Avatar
I had the same issue (sloped garage floor) when doing my MT trans fluid and rear diff fluid. Like OP I used a level on the door sill. No issues, worked fine.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Old 09-16-2016, 09:58 PM   #12
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
I'd check the car level on the pinch weld rail, not on the engine or the interior.
The Following User Says Thank You to Mr.ac For This Useful Post:
Ultramaroon (09-17-2016)
Old 09-16-2016, 10:08 PM   #13
Old 09-17-2016, 03:42 PM   #14
The_mediocre_guy
Drives: 2013 subaru brz ltd
the paranoia in this thread is real
The_mediocre_guy is offline   Reply With Quote
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 10:39 AM
FRS/BRZ Volume level Scionguy28 Electronics | Audio | NAV | Infotainment 7 12-03-2014 08:31 AM
Fuel level GeeTee86 Issues | Warranty | Recalls / TSB 6 05-21-2013 06:57 AM
My oil level was low! FRSjeff Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 12-16-2012 12:22 AM
Another Level 86's SportInjected Great Lakes 4 07-30-2012 11:13 PM
