Old 09-15-2016, 01:06 AM   #1
SpeedDemon26
Window problems! HELPPPPP!!
So, my passenger window stopped working last week. So today when messing with it it would go down, but not up! It only responds from the passenger side window control too. I've tried using the drive side switch and no movement in either direction and not audable noise of the motor clicking. When I press the button for the window to go up it doesn't move nor make a noise. But when the window was all the way up I was able to fully roll it all the way down (but sadly not back up). I'm completing stumped on what's broke: the window motor, the passenger switch, driver switch, or does my car just hate me for leaving it sitting for two months?
SpeedDemon26 is offline   Reply With Quote
Old 09-15-2016, 01:27 AM   #2
Well now, @SpeedDemon26 that's a bummer.
First thing I'd check is the fuse. It's in the #14 slot (25A) in the fuse box under the hood.
While you're there, might as well check the other sides fuse also (#10 position).
If the fuse is OK, the next thing I would suggest to do it take the switch out and test it.
Then we can go from there .....
Calling @Ultramaroon - he is a window expert .....
Old 09-15-2016, 02:31 AM   #3
What? I don't do windows. :/
It's not the motor because it works going down. Are you sure the stupid passenger window disable switch isn't pushed in?
It sounds like you might have pushed in the button after the window went down. It kills the passenger window from both doors. I don't know what the hell it's for other than to fuck with people.
humfrz (09-15-2016)
Old 09-15-2016, 03:16 AM   #4
Good thought.
It's there so I can keep mrs humfrz from jumping out, when I'm driving on mountain roads, ...... she may be tempted to take her chances rolling down the side of the mountain ......
Ultramaroon (09-15-2016)
broke, window
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-05-2016 12:18 AM
OPF 91 STAGE 1 Engine knock HELPPPPP!!! adrianlam Software Tuning 1 05-17-2016 08:19 PM
Helppppp bolt pattern adapter Diz86x Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 10-03-2015 10:34 AM
2013 BRZ limited window problems?? celeste88 BRZ First-Gen (2012+) — General Topics 14 12-19-2014 10:56 AM
Passanger window problems jaymannj Issues | Warranty | Recalls / TSB 11 12-14-2013 12:23 PM
